Turbocharger Installation... complete!! **PICS**
#83
Originally Posted by 4pumpedCL
I was curious what your ECR valve is positioned at? According to my calculations if you advanced it 24.5 degrees you would see a small/ yet noticable difference. I would reccomend putting a Matco I-port off the ecu...tune it at 4500 rpms, in peak invervals. Good job!
#84
Beware of leakage
Originally Posted by scalbert
I assume he should also making some adjustments to his discronificator settings to get the most out of it. ![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
![Bow](https://acurazine.com/forums/images/smilies/bow.gif)
That engine bay looks
![Drool](https://acurazine.com/forums/images/smilies/drool.gif)
I hope work will bring me to Cali in the near future, I would love to see this beast in action.
#85
Originally Posted by allmotor_2000
Upto 20% even at 3.5K RPMS all the way to 35% at redline. I don't remember exactly... I can forward the map to you if you'd like. I have to look at it in the E-manage to determine what the injectors are at under WOT/max-boost.
What type of pressure gain from the FPR are you seeing?? What is the BC setting??
Never mind, just email it over and I'll take a look at it.
But wow, 35% addition. You need more pressure, larger squirters or an additional one (or two).
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
#86
I am running very bald stock tires. 1st gear spins even if I dont' push it... the rest of the gears are fine.
How did you manage to keep the stockers this long?? I have 20k miles and am on my 3rd set. :o
#88
Parting out 02 Type S :(
allmotor, we should do another quick run to see how bad i will lose to you. glad to hear you got it running, sooner than i thought!
now we are both running on bald tires, mine are almost out thanks to the sc!
call me up if you get a chance, peace/
#89
#90
What kind of rubber are you considering upgrading to?? Something decent but priced well as you will be going through them quickly. ![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
#91
Please do send it over.
#94
still a Masshole
#95
Blown is Best
#97
Honkey
I wouldn't even mess with that unless you have the SSR-R2D2 disconification calibrator!
#98
i was just calibrating my R2D2 earlier today. fast as hell now.
![](http://www.cs.usm.maine.edu/~monkey/images/r2d2.jpg)
#99
SHIFT_over.so.I.can.see
that turbo looks too good to be true...
I hope I can be at the track to pick up the pieces of clutch and axle if you ever track this bad boy...
how many clutches has it been now ram?
#104
BC is at 2.75V - haven't messed with that yet. I am seeing upto 86psi on the FPR. I definateley need something bigger very soon!
![Confused](https://acurazine.com/forums/images/smilies/confused.gif)
Just a guess but it fixed the issue. That, or it was a coincidence.
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
#106
With the IC kit, would a turbo fit in the auto CL-s Tl-s? There would be alot less piping to worry about. I've never actually seen a turocharged car with an Air to water cooler, but I guess that'due to the extra cost?
#107
But one of the main problems with the piping isn't the IC and intake, it is the exhaust plumbing. The 5AT transmission housing is larger leaving less room for the exhaust plumbing.
BTW, the Syclone and Typhoon used a liquid/air IC system from the factory.
#109
I guess the only place to mount a turbo on the auto is under the car? Need to think this one over
Yes it could work.
BTW, the Syclone and Typhoon used a liquid/air IC system from the factory.![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
#110
Audi S4 driver
There should be plenty of room for a turbo on the auto, in the hole that all the horsepower\torque will blow through the side of the case. I can't ever see a 5AT lasting with that much power
#112
Registered User
Originally Posted by ABChin324
I would like to buy the turbo...."if you make it, they will buy!"
i used to have a turbo on my Civic Si, and can't wait for another turbo setup on my car
#119
From what little I have seen in an auto CL-S, it will be very difficult to configure a turbo similar to the 6-speed setup. It will have to be mounted under/behind the engine at the back, I believe!
#120
