TSX rotors
The front rotors are the same size. The rears are different. The CL's are 11.1 inches and the TSX is 10.2 inches in the rear. According to the Powerslot website, the front rotors are the same.
If you're getting new ones, I would go with the Rotora slotted. To get them all resurfaced should not cost more than about $200.
9th Gear
Thanks for the input. I practically have a set of TSX rotors from my TSX that only have about 1400 miles on them (I am modding the TSX and changed out the rotors and pads) and was thinking of just using the TSX rotors on the CL since they are shot anyway. The rear rotors and pads are fine, just the fronts needs to be replaced. Do you think I should just use the TSX rotors and have them resurfaced or just go out and get new rotors altogether?
From all I saw, the model numbers for the front rotors are the same for both cars.
Powerslot selection guide
The Brembo one is also the same part number.
If there is only about 1500 miles on the TSX rotors, you should be fine with them.
GWEEDOspeedo
01-15-2016 10:39 PM
