transmission fluid low
about a week ago i noticed the transmission slip a few times, and downshift kind of hard. I checked the fluid, and it was low (did not even register on the dipstick). Went to honda, bought some fluid, filled it up via the dipstick hole and a makeshift funnel - i put in an entire quart of fluid, and its still not showing at all on the dipstick. So now im nervous, maybe im somehow a moron and doing something wrong. Question, the dipstick shows transmission fluid on 1 side of it, but the other side is bone dry, it should be on both sides right? I am checking it when the car is hot, but turned off, correct? maybe it was just short more then a quart of transmission fluid, but that seems like a lot
this is how I got my transmission replaced, it started leaking fluid, it was shifting OK though, leaving spots on a drive way, took it to dealer and they said the transmission seal is leaking and to replace a seal is pretty expensive, so they recommend transmission replacement. They also told me that leaking fluid could be a sign of failure, so replacing a seal could be waste of money
I worked at Tire Kingdom for a few years and the red neck/meth head mechanics schooled me about trans flushes and checking fluid levels.
run the car till its normal operating temp, pull the stick, wipe it, re-dip, pull without dragging the sides (or at least 1 side), check level. ALL WHILE RUNNING
Honda/Acura states car off on level ground. If you fill your trans while engine is running it will be overfilled.
Owner's manual > *
mada51589
05-03-2022 08:54 PM
HeloDown
09-08-2015 06:51 PM
