Transmission Filler Plug Location??
Diablo Tejano
Ok, I believe I have this right but want confirmation before I start taking what I believe apart.
Is this the 'jet' that was installed into my filler plug?
I have the proper honda fluid, how much goes back in with a drain and fill? ('01 3.2S)
TIA
TIA
![](http://www.gunco.net/gallery/data/500/medium/trans_005.jpg)
I believe it is drain 2 quarts, fill, drain2, fill, drain2, fill again. I am not sure that there is a way to get it all out at once.
I'll let someone else give the right information though. I don't know about the oil jet kit at all.
Blown is Best
You're in the right spot. Yes that's the filler plug below the oil jet. I think you pull the bolt holding the oil jet bracket in place and remove the oil jet. You then can loosen the filler plug that now has a hole in the top for the oil jet.
i guess you are doing a standard drain and no flush. i'm doing that too this week, except installing transmission cooler and redline HT ATF. comptech over the phone told me drain it and fill it. Drive about a few hundred miles 300-500, then drain and fill it again. this will make sure all old fluid is out if you are not flushing.
Diablo Tejano
Ok, great then. I will drain and fill it twice. Anyone know exactly how much it's supposed to hold?
Got to shorten that hose too, it seemed a bit 'kinked'...
BlkTxAcuraTypeS
10-18-2015 08:05 PM
