Tranmission cooler 01 CLSA
To many cars in my garage
Thats exactly what I wanted to here
Did you notice any difference on a reallly hot day when you were guning it alot ( BTW I wouldnt think you would im just doing to make my transmission last longer but I though I would ask)
This post should be the DIY BTW
I Finally installed my tansmission cooler
I noticed that when I gun it on the highway it does kick down as hard which is good because it was shifting way to had in my opinion
Also I felt the transmission cooler after driving and man I didnt realize It was getting that hot
BTW thanks everyone for the pics
B A N N E D
Location: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
Was the install hard? How long did it take u? DId u go with the comptech tranny cooler? Did u have to add fluid to compinsate fo the extra hose and tranny the fluid flows through, if so how much?
Sorry for all the questions but i been on the fence about doing this for like 2 years!
B A N N E D
Can u also take some pics of your install PLEASE, like the new connections and the cooler?
I dont have a camera right now but my pics will look the same as everyone else
The problem with our transmission has nothing to do with the heat this is true but I have heard it will double the life of your transmission so it doesnt hurt
Wasnt hard took about an hour the hardest part was figureing out which line to pull the pics are not greeat but its the only hose behind the intake if that helps
I went with a genaric cooler mine was about 12" /18"
I checked the fluid its in the normal range but a little low so im going to add probably a 1/2 quart when I have time to go to honda/acura Dlr
If you take a pic I will mark which hose to disconnect if you want
B A N N E D
Yeah that would be great I wanted to do this for a while now.
is this pretty much how u do it?
http://www.autocarparts.com/part/937/3/
Click instalation instructions, next to description
I installed in my car a month ago and never hooked it up because I was a little confused but when I pulled the line off It was easy
I did have touble pulling the line off and didnt want to break it because I wasnt sure if I was pulling the rite line but one day I was like fuck it and took a pair of pliars and ripped it off it was easy afterr that .
Just hesitant to get in there and do it.
For sure but dont be scared its easy just make sure you have extra hose because I had to go get some in the middle of the install you need about 8'
I garuntee you wont pull the wrong hose because there is only one hose and I bet (like me) you are looking at it going is that the right hose well it is so pull it off already
P.S. I wasnt even sure when I got it off if it was the right one or not so I cut it open and put some of the fluid on a whit piece of paper just to make sure
B A N N E D
Why dont someone post a DIY for DUMMIES so i can figure it out myself..
P.S. make sure there is ALOT of pics!
The easiest way to do this is take a pic so you know what the pic is of then I will show you eactly what line to pull
There is honestly only one line in that location and even if you pulled the wrong one its easy to replace because you will have the line for it
PS I put the line off , if there is next to no fluid in it. it is OK there is barley any in it when it not running
Im looking at the original pic that e30 posted and its kinda of confusing because there is two lines but when you start there is only one about 6-7" long so just keep this in mind when looking at the pic that he posted
Uses turn signals in my
Bringing up an old thread.
I installed a trans cooler a few weeks ago and man it makes a nice difference for driving. The car shifts much more consistently even after an hour+ driving in stop and go traffic. It is a great mod for anyone considering it. I spent less than $100 when all said & done. $30 for the Hayden cooler, $30 for ~11 ft of 3/8s line and ~$30 for Honda ATF (decided to do a 1x drain and refill while I was adding the cooler).
lanechanger
10-13-2015 10:56 AM
