Torque Spec?
2003 CL-S 6MT
Torque Spec?
Does anyone know the torque spec for the nuts when installing headers on the block? Also, I just received Ralco Pulleys they stated a torque spec of 181ft-lbs. Does that sound right?
Blown is Best
Here are the torque specs for your header install:
23 lb/ft for the bolts that connect the header to the head.
40 lb/ft for the bolts that connect the header to the "A" Pipe.
25 lb/ft for the bolts that connect the "A" pipe to the converter.
Crank Pulley torqye sounds about right too.
emailnatec
29
09-28-2018 04:27 PM
