The Top 10 "MUST HAVE" CL Modifications
I thought it would be interesting to see what kind of lists people would come up with and why they chose the mods they listed.
This is assuming that you have a bone stock Acura CL with no mods. |
Well prob most popular are:
Intake, exhaust, headers, springs,shocks or coilovers, sway bars, strut brace, wheels, and supercharger hehe |
-brake upgrade
-pulley's -lip kit -roof spoiler |
#1 Lower the car. Should be done before anything IMO
The car is a pig and you'll notice the most difference in improving the braking and handling characteristics. If I were to start fresh I'd do it in following order:
BBK Coilovers Sway Bars Header Intake After that depends how much you want to spend. These should be a standard though. |
For a 6MT:
1 - PSpec short shifter 2 - Corsport shifter bushings 3 - Syncromesh tranny fluid 4 - Headers 5 - Intake 6 - 2.5" exhaust 7 - Drop it 8 - Wheels 9 - BBK 10 - TL lip kit For 5AT: 1 - Swap in 6MT. 2 - Follow steps 1-9 on the list above. |
(Post 11936675)
For a 6MT:
1 - PSpec short shifter 2 - Corsport shifter bushings 3 - Syncromesh tranny fluid 4 - Headers 5 - Intake 6 - 2.5" exhaust 7 - Drop it 8 - Wheels 9 - BBK 10 - TL lip kit For 5AT: 1 - Swap in 6MT. 2 - Follow steps 1-9 on the list above. the 3 minimum for me is Headers Drop BBK |
lol IMHO
Headers is NUMBER 1.... 20+ hp for a single bolt on is a must. intake BRAKES (all around.. pad and rotors at a minumum) option underdrive pulley progress rsb MOOG end links exhaust those are the MUST HAVES in my experience now that I've owned a stock CL-S 13 months ago and now it's modded to the tits now. I didn't choose that order but looking back that would be the exact order. MY order of mods (main mods... not little things, to the best of my knowledge) however are/were: injen CAI option underdrive pulley p2r plenums p2r throttle body spacer Progress RSB sway Ebay mesh grille Moog end links p2r thermo gaskets for tb and manifold DBA fr, EBC rr.. Adaptive One pads (napa) Comptech Headers wrapped with DEI Comptech front sway. the best mods for the money ARE: option pulley about 10hp for 70-80$ (including belts) headers 20+hp for 400-700 (depending on brand and condition) CAI intake 10+hp (i'd buy one used if i could find one) Progress RSB (car feels like a WHOLE NEW VEHICLE) my most impressive mod for sure... right behind the option pulley. I hope this helps FYI headers is like adding the biggest smile on ur face I SWEAR TO GOD it did for me!!! intake... nice sound.. meh option pulley... omfg what a difference all around. I am astound it made more of a difference than the intake.. MY WORD. people think differently tho cause the sound makes them feel like they are going way faster... as sexy as that sound is |
Originally Posted by 98JDMCL
(Post 11936543)
Originally Posted by Rejckt
(Post 11936831)
Supercharger only good if your auto. After my 6mt swap, I wanna sell my ctsc for a turbo setup.
and when your are going to sell it :wish: |
(Post 11936831)
| v :D |
correct me if i am wrong but u don't need (tho it would help) a tune to run a supercharger ??? just the FPR ... if you are running 8 psi or less.
or is it more complicated than that? |
(Post 11936675)
For a 6MT:
IIRC 04-06 TL 6MTs are the same, so youre not looking for just one model year with limited production.
You could also pick up an Accord tranny and buy the LSD elsewhere. |
(Post 11936675)
For a 6MT:
1 - PSpec short shifter 2 - Corsport shifter bushings 3 - Syncromesh tranny fluid 4 - Headers |
comptech does or u'll have to find some used comptechs or used xs headers.
or get any set and cut the pipe on the rear header that needs to be modified and geter welded up |
The top 10:
1.) Lowering 2.) Brake Rotors 3.) Rear Sway Bar 4.) Exhaust 5.) Headers 6.) Ice Box 7.) Crank Pulley 8.) Wheels and Tires 9.) Motor mounts 10.) RWD |
(Post 11937239)
You could also pick up an Accord tranny and buy the LSD elsewhere. Also, I heard with the Accord trans you have some fitment issues.... afaik. Just heard that if you swap in an Accord manual trans, it's really more work than it's worth. |
Everything in my sig plus better motor mounts/radius rod bushings are essential.
And if I can find a suitable donor 6mt, that too. |
Originally Posted by StreetKA
(Post 11936894)
you mean that SC is better for auto ? why ?
Originally Posted by CL-S progression 01
(Post 11937211)
or is it more complicated than that? Right now I use rc440 w/ emanage blue, no problems... but my luk clutch/ flywheel is slipping. I have a cm stage 3 sitting next to me tho. |
(Post 11937143)
Oh really?
| v :D But I want a new pc :pc: |
(Post 11937377)
And if I can find a suitable donor 6mt, that too. LOL . . . Better mounts . . yep if we can ever get a working set they would be on my top 10, maybe even top 5. My :2cents: on brakes is that the OEMs are weak and an upgrade is a top 10. However I'm not a fan of BBK . . . they add unnecessary weight which negatively impacts acceleration, steering and braking feel and or response. Ruf |
Originally Posted by RUF87
(Post 11937642)
(Post 11937642)
My :2cents: on brakes is that the OEMs are weak and an upgrade is a top 10. However I'm not a fan of BBK . . . they add unnecessary weight which negatively impacts acceleration, steering and braking feel and or response. Ruf Rotora bbk front, 2pc rotor rotora rotor rear /w teflon lines. |
#1-Acurazine stickers, after that who cares.
6 speed
1. drop 2. FULLL exhaust (headers, cat, pipes, muffs) 3. tires 4. Rotors and pads 5. synchromesh 6. valve adjustment 7. intake 8. Mounts 9. engine dampener 10. pulley |
It's all subjective.
I would only do 2 things if I did it over. Headers Good tires in 235-45-17. I wouldn't touch anything else. |
(Post 11937547)
I've been trolling that thread :run:
debadge
intake drop rims custom front grille headers exhaust tint audio steel braid brake lines back window spoiler |
Originally Posted by Jacobpockros
(Post 11937317)
The top 10:
Originally Posted by manny3010
(Post 11943425)
How do you do #10 and is it possible in a automatic base model?
^ lol yea it has. I didnt do the lip kit.
Yet. |
Haven't had the chance to put my 01 5AT CL-S under the wrench yet but if i had the $$$
(and this is based on what i've seen and researched so far...) 1) Drop (Full coilover setup w/tophats preferably Tein SS-P or KSport Control Pro'z AND Rear camber kit) 2) Brake upgrade (Rotors, SS Lines, and padz) 3) Wheel/Tire setup 235/40/18 wheels take ur pic... 4) Headers (CT or XS) 5) Intake 6) upgrade factory sways and strut bar 7) TL Lip kit conversion 8) Sarona Rear Roof spoiler 9) 6MT TL or Honda Odessy Trans swap 10) CT S/C setup and depending on what yr u have I'd also do 11) 03 blk housed headlights 12) 03 tailights and Audio is a MUST for these cars IMHO with that crappy 1ohm Bose setup! |
lol i happen to think the sound system is damn good... for a stock 2001 ride... the system was definitely ahead of its time
I have no problem with the speakers themselves. I think you just need to replace the headunit to take better control of the equalizer. I havent replaced the stock speakers yet because they sound pretty good, and until they blow I wont put my Infiniti's in (which says alot, because the Infiniti Kappa Perfects are IMO the best speakers out there).
(Post 11950042)
(Post 11950619)
No factory navi (and Im glad).
I got a Pioneer Avic F90bt. Its not bad but its definitely not the greatest. |
(Post 11936755)
lol IMHO
03 cl-s 6mt
Guys I am new to the forum so bare with me… I got a black 03 CL-S about 4 months ago and want to really getting into modding it this summer. So far I have only put 06 TL wheels on, PSPEC short shifter, tint, those supercomputer pedals and custom sub and amp rack enclosure. I am coming from a lifted truck so this is all new to me. What I want to know is what you would suggest being the next things for me to do. The top ten lists are helping out but I would like some advice. Like my brakes are going so bad so that might be a first for me, also the car doesn’t shift as smooth as I would like, could that synchromesh help. Thanks in advance for the help everyone…
If brakes are next.
Go with a cross drilled rotor set up and ceramic pads. Rotor will run cooler and stop beter. ceramic pads will have very low brake dust and their quiet. Also you can get a whole cheap brand set up for $160. |
| All times are GMT -5. The time now is 08:39 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
