Took my sunroof visor off...
Yesterday i washed my car and decided to take the sun visor off. I never really use the sunroof because it doesn't go that far back and with the visor, there is just no open space. I think it looks better but it left a mark on the paint where the visor was touching it. I tried a clay bar but it didn't help much. it got the dirt off but there is like a clear scratch. Any ideas on how i could get this off? It goes all around the front part of the sunroof. I don't want to put the visor back on unless its a last resort. Would touch up paint be worth it? thanks in advance.
marc
marc
I take my visor OFF every winter so the road salt doesn’t get under it.
Last winter when I removed it I noticed exactly what you noted.
The paint actually seems to be “indented” where the rubber touches it.
I ZAINO’d the hell out of it and it still looked the same.
The funny thing is I had a visor on my 91 Legend Coupe for EIGHT YEARS and it never did this.
The same for my wife’s 91 Integra, I remove it for the winter and never noticed it on her BLACK paint.
It must be just another example of the CHEAP paint on our cars.
On the bright side, it makes it quite easy to properly align the visor when I put it back on in the spring.
Shawn S
Shawn S
Its easy to take the visor off. There are 2 screws you have to take out (1 on each side) and then open the sunroof and take off the brackets. Took me 2 minutes to do. I don't know if i should leave it offf or put it back on, i really like it without it tho, but i don't want that "indent" there.
marc
marc
Despite my request NOT to, the dealer installed a sunroof visor on my car prior to me picking it up. 4 days later I took it off and it left the same marks you guys are talking about -- looks like a "dent" in the paint everywhere the rubber strip touched. Nothing took it off -- I ended up taking it back to the dealer and they had to farm it out to a body shop that wetsanded it to remove the mark. I wasn't too excited about having that done to a 10 day old car, but they did a great job and the mark is gone.
Originally posted by RAdams:
<STRONG>Despite my request NOT to, the dealer installed a sunroof visor on my car prior to me picking it up. 4 days later I took it off and it left the same marks you guys are talking about -- looks like a "dent" in the paint everywhere the rubber strip touched. Nothing took it off -- I ended up taking it back to the dealer and they had to farm it out to a body shop that wetsanded it to remove the mark. I wasn't too excited about having that done to a 10 day old car, but they did a great job and the mark is gone.</STRONG>
What would a job like this cost? I would consider doing it if it isn't to expensive. I really don't want to put the visor back on. From the inside, its so much better without the visor.
marc
[ 10-11-2001: Message edited by: Marc S ]
Powered By HONDA
yah touch up paint will help and eliminate the situtaion.that is all u can do.otherwise u want to repaint that small part?i do not have sunroof visor and i think that makes the car uglier that is why i do not buy and will not intend to buy in the future either. now i know removing sunroof visor will scratch the paint on the moonroof areas.thanks for the info. :p
Originally posted by Type S:
<STRONG>yah touch up paint will help and eliminate the situtaion.that is all u can do.otherwise u want to repaint that small part?i do not have sunroof visor and i think that makes the car uglier that is why i do not buy and will not intend to buy in the future either. now i know removing sunroof visor will scratch the paint on the moonroof areas.thanks for the info. :p</STRONG>
I don't know it i want to use touch up paint, cause we all know that it could turn out to be a mess. But is sanding it out a possibility? How much would something like that cost?
marc
Stage 1 Audi S5
Originally posted by Marc S:
<STRONG>
Im so glad my misfortune could help you :p
marc</STRONG>
<STRONG>
marc</STRONG>
Powered By HONDA
i honestly do not like to use touch up paint either.the scractches are too tiny and the touch up paint's brush is too big and too wide.so what i do is using a tiny sharp stick such as sewing needle,stick it with the touch up paint and carefully apply it to the scratch areas.do it slowly and patinetly.u might get the result u want.good luck
[ 10-11-2001: Message edited by: Type S ]
The Creator
NO. DO NOT USE TOUCH UP PAINT!
If it trully is a "dent" in the paint, there prolly nothing you can do.
If it is just fine scratches that wore away some of the clear coat... try 3M Swirl Mark Remover, Part #39009... that should return it to a nice mark free finish, then just wax/zaino over it. If you cant get the marks out with that, start out with a more abrasive compound, then follow up with the 39009... then zaino/wax.
Thanks for all the info. I wouldn't consider it a "dent" i would consider it more of a scratch. but its a big scratch. It looks like it scratched up every part where the visor was resting. I think its just cheap paint. I just don't know what to do. I know i won't mess with touch up paint. I will most likely try what soopa suggested and i will keep you guys posted.
marc
marc
mlody
12-04-2019 02:11 PM
