Tire/Wheel Combination Calculator
Which Brings up A Good Point
225 vs 235 - 17s
225 235
Width +.39 +.79
Sidewall height -.25 -.07
Overall height -.49 -.14
Circumference -1.55 -.43
Given this information, the 235 seems a MUCH Better Option than the 225, at least closer to Spedo.
225 235
Width +.39 +.79
Originally posted by 02 Aegean CLS
oops
I guess that I forgot to put the link in:
http://www.tolan-hoechst.com/cars/tirecalc.htm
oops
![Sleep](https://acurazine.com/forums/images/smilies/sleep.gif)
oops
oops
Re: Which Brings up A Good Point
Originally posted by caddy
225 vs 235 - 17s
225 235
Width +.39 +.79
225 vs 235 - 17s
225 235
Width +.39 +.79
need 10% more someplace else..
225 vs 235 - 17s
225 vs 235 - 17s
<pre>
<font size=+1>
225 235
Width +.39 +.79
</font>
</pre>
For accuracy to speedo -- yes!
However, some tires in a 235 (like the Kumho @ 27.5lbs) weigh a bit more than the stock tires. Since the bulk of this weight is concentrated at the steel belts, it makes for a loss in acceleration. (The Kumhos in a 225/45-17 size have a weight close to the stock/OEM MXM4 tires.) Finally, most of the 235/45-17 tires have a minimum rim width of 7.5” (BMW and others car makers sometimes put tires on ½” undersized rims.)
So, the 235 < -- > 225 issue depends on the brand and if it is going on the stock rim.
Then you have 235/45-17 Toyo T1S on stock rims -- they fit and work great, but the alignment is a bitch (due to the thick sidewall protector and funny outside flange on the stock rim).
Finally, while the calculator is great for wheel and tire sizing issues (combined with offset calcs), it will NOT tell you the actual speedo error. It is better to look at TireRack (or Michelin) for the stock Revs/Mile spec to compare against the Revs/Mile spec of the replacement tire. Different tires have different loaded radii depending on the construction of the tire.
Re: Re: Which Brings up A Good Point
Originally posted by EricL
Table moved to here:
<pre>
<font size=+1>
225 235
Width +.39 +.79
</font>
</pre>
<pre>
<font size=+1>
225 235
Width +.39 +.79
</font>
</pre>
Re: Re: Re: Which Brings up A Good Point
Originally posted by CO-CL-S
Or get a GPS and do your own calibration tests (I found the stock tires to be off app. 1.2% ..
There was that guy who had a AAA test and 150+ on the speedo was no more than 147 MPH
![Boink](https://acurazine.com/forums/images/smilies/boink.gif)
(Perhaps some 205/40-17 replacement tires would help some of the speeders avoid more tickets)
Hmmm... I don't think the GPS has a crystal ball satellite feature for getting different replacement tires...
![Confused](https://acurazine.com/forums/images/smilies/confused.gif)
Oh, and then you can recalibrate (via the GPS) as your tires wear out -- since this changes the diameter of the tire by:
25.4" when the tires are new to 25.4" - 20/32" when worn out
![EEK!](https://acurazine.com/forums/images/smilies/eek.gif)
spoiler900
10-10-2015 06:48 PM
