Ticking Valves
Old Aug 11, 2008 | 10:21 PM
civicdrivr's Avatar
Ticking Valves
My valves are pretty noisy at idle. The car has alittle over 57k on it. Is there a need to worry or have them adjusted? Ill try to take a video of it tomorrow.
Old Aug 11, 2008 | 11:05 PM
fuzzy02CLS's Avatar
It's common. Some are worse then others. If you need to adjust them, then go ahead.
Old Aug 12, 2008 | 12:12 AM
civicdrivr's Avatar
Ok. I wasn't too sure as all of the other J series I've known had less than 40k miles on them (J30 and J35).
How much does it usually cost to have valves adjusted and when should I need to do it?
Old Aug 12, 2008 | 07:33 AM
fuzzy02CLS's Avatar
When is a toss up, Like I said some are worse then others & some live with it.
The top end of the engine needs to come off. It's all going to be labor. Figure 4-6 hours labor.
I think someone did a write up on it.
Old Aug 12, 2008 | 12:37 PM
TheWeez's Avatar
I Wanna Beer
I recall a previous thread basically coming down to that a well trained mechanic should be able to tell if they need to be adjusted or not just by listening to it.
Old Aug 12, 2008 | 01:22 PM
civicdrivr's Avatar
Ok. Thanks guys. Ill do a search on the topic.
Old Aug 12, 2008 | 02:12 PM
02CL-TypeS's Avatar
what will happen if you don't adjust ticking valves? I noticed you said people just live with it. Mine tick, but you can't hear it from inside the car
Old Aug 12, 2008 | 03:05 PM
fuzzy02CLS's Avatar
Also note the fuel injectors tick. It's very common on Honda V6 engines. This could be mistaking for valves ticking.
Old Aug 12, 2008 | 07:50 PM
djarovsky's Avatar
https://acurazine.com/forums/ramblings-12/number-posts-196766/
.....and it is best to get an expert opinion instead of relying on sound alone. There are too many things that can be confused for valve noise (fuel injectors, purge control solenoid valve, etc.).
fifer16
1G RL (1996-2004)
Nov 22, 2024 07:07 PM
Mike734
Dec 10, 2021 01:25 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
MilanoRedDashR
Sep 24, 2015 11:04 PM
TL14
Sep 24, 2015 04:37 PM
