Throttle Cable Replacement
Thanks for the replies on my last thread. Here is another.
I again have searched the 2 gen CL threads and have not found anyone who has done a DIY on a throttle cable replacement. My Mechanic advises I do it, and the petal does kind of hesitate then lurch. I ordered the part from Criswell Acura in Annapolis for $27.00
At first I adjusted it tighter, but the cable is stretched and I am better off doing the replacement.
Can one of you all reply with a link to this issue or Discuss personal experiences with this.
If there is no DIY I can create a quick on.
I got my degree at the end of the summer and am searching for a job so I have plenty of time for stuff like repairs on the AK.
I work on boats a lot. I have had to replace throttle cables and shift cables before. They can stretch (feels like it slips out of the sheathing).
I had adjusted mine a little, but I still think it needs replacement.
Per the Helms manual:
Throttle Cable Removal/Installation
1) Fully open the throttle vlave, then remove the throttle cable from the throttle link.
2) Remove the cable sheath from the cable bracket.
3) Remove the throttle cable from the accelerator pedal.
4) Pull off the throttle cable from the vehicle.
5) Install in the reverse order of removal.
6) After installing, start the engine and hold the engine speed at 3,000 rpm with no load (in Park or nuetral) until the radiator fan comes on, then let it idle.
7) Remove all the slack from the cable while holding the cable sheath.
8) Turn the adjusting nut until it is 3mm (1/8 in.) away from the cable bracket.
9) Tighten the locknut. The cable deflection should be 4-6mm (3/16-1/4 in.). If deflection is not within spec, readjust the nuts.
10) After the cable is adjusted properly, check the throttle valve whether it is able to fully open and close smoothly with acceleration.
Thank you so much.
I love this Forum
Yes, my deflection is much more than the spec. listed here.
Probably like 5 mils.
I love this Forum
If possible while you are there at the Throttle body, check to see if it (the valve) moves freely within the TB. These things tend to collect alot of particulate that collects there and inhibits free movement. Some lacquer thinner on a rag with your finger will do a good job on the quick. Throttle response should improve, which you will notice.
lowrd on tein CS biatch
i personally cannot see a hesitation being created by a slightly stretched cable. i think it's a sensor going, or spark related ie plugs or a coil goin on u.
i had some weird shit happening to my car the rpms ere going all over the place. i just disconected all the connections by the TB.. so that's 5 connections or so.. plugged them back in and it was back to perfect really weird shit.
just a lil fyi
just a lil fyi
I got the Shifts
your mechanic has port-o-potty syndrome.
he is full of shit.
hesitation is caused by:
lack of maintenance,spark plugs, bad coil pack, low oil, over heating, failing sensors,dirty throttle body, failing fuel pump.
is your car automatic? i bet your lurching is from a failing transmission.
he is full of shit.
Glad I found this. My throttle cable snapped (yes snapped) while driving last night. Had to get the car towed back to my house. The replacement should be in at the dealership tomorrow..Looking at the steps above, replacing it should be about a 30 minute job; just damned inconvenient.
civicdrivr (01-05-2012)
Whats up with RDX owners?
His car isnt the first CL that this has happened to and Im sure it wont be the last.
Its really not a long job, its just difficult working under the dash.
cycdaniel
12-17-2019 10:58 AM
kixo
09-01-2015 06:27 AM
