Thermoblok = maximum gain 8.5 whp and 9.1 ft-ESTING RESULTS - Honda J Series V-6 ???
#42
Originally posted by darrinb
yea, lets get this up and goin 5-10hp aint bad for 85 dollars
If you are crusing, there will be little to no benefit from this.
#44
my right foot is always deep into the throttle
#45
Spectacular Aroma About
Originally posted by mattg
i emailed hondata a few months back asking about the heatshield gasket sets they make for 4cyl's such as the rsx. they said it wasn't feasable for our v6 application. they said our intake manifold won't line up properly w/ the spacers installed. something like that anyway.
Edit: After looking at the Helms it seems there is a dandy spot to insert one of these between the lower intake pieces and the plenum. Should accomplish the same thing. What are these things made out of anyway? I just got a new Dermel for Christmas.
#46
#47
Originally posted by scalbert
Right here:
Right here:
#48
Radiator fluid (coolant) is run through the throttle body to keep ice from forming there. This heat would spread to the intake manifold. If you don't live in freezing/cold weather the throttle body can be bypassed
#49
That's the spot. Looks like an easy installation too. I would think one of these could be made easily. I wonder if the TB spacer would still do anything or be needed with the intake spacer?
#50
#51
Like this: TB Hose Bypass
#52
Originally posted by typeR
should us auto guys bypass the VSA as well? and while on that subject if port the TB like mugen would it not be nessecary to do the VSA or just remove it?
The VSA throttle would be a limiting item as it is still in the path. However, I never took any measurements of it to know the size. If it is already bigger than the TB then no need; but if the same or smaller then it might be somethign to look at.
As for removing it; that could be done. In fact, you could just pull it out of the intake tract and tie it off below so no electrical tricks are needed to not set a DTC.
09-17-2015 09:01 PM
16176p8aa01, 30, 32, 99, acura, acurazine, gain, hondaacura, hondata, intake, jseries, kit, manifold, spacer, thermoblok, tl, v6, whp, wwwzapatinp8a
