test pipe question
test pipe question
as of now I have a stock cl type s mt. I just bought a ice box and I was thinking about getting a test pipe from excelerate. does anybody know how it sounds on a stock exhaust set up?
The following 2 users liked this post by Karanx7:
civicdrivr (07-01-2012),
p.diddy (07-01-2012)
Whats up with RDX owners?
Ive got a full 2.5" exhaust for sale
![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
@Mikeshlong On IG
So this bolts on easily and makes your car not pass smog, but makes it loud and slightly increases power ? Sorry if I am completely wrong guys. but at $127 it seems pretty nice.
Dont forget the free carbon build up on the bumpers and the nasty smell.
And the possibility of a check engine light.
But it can be yours for the low, low price of just $127!!!
The following 2 users liked this post by civicdrivr:
SlickShiftNall6 (07-01-2012),
YeuEmMaiMai (07-06-2012)
Certain HFCs can throw a CEL, but I havent gotten any in over 2 years running one. It will still pass a visual inspection, you dont get the buildup on the bumper, nor do you have the nasty smell. A test pipe may make more power then a high flow cat, but you wont even be able to feel the difference (we're talking maybe 4hp).
mikebikelife (07-01-2012)
XS headers, Magnaflow high flow cat, Comptech b-pipe, Magnaflow resonator (kills drone and rasp), Comptech mufflers. All 2.5", using v-band clamps on all but the muffler flanges.
how much does a test pipe make over stock, and then over a high flow cat? Do we have dynos? With a test pipe your always going to have a CEL and raspy sounds (but if u get a resonated one it will lessen the raspy sound a bit). Hope you find some good info here
jipper (07-01-2012)
Unregistered Member
It is NOT cost worthy. The stock exhaust is pretty non restrictive (minus exhaust manifolds). Modern cats don't restrict too much HP. HFC have been made popular because older cars used to restrict a lot of HP with primitive cats, so people got a shitton of HP for free (steel pipe).
jipper (07-01-2012)
I wouldnt say that about all modern cats. Take a look at the 3G TL/8G Accords and precat deletes/high flow cats. They made some nice power with those mods. Or look at the supercharged Jags. HFCs have been proven to make ~40hp over stock. I think Evo Xs and MS3s have been making more power with HFCs then they do with test pipes too, but theres another explanation for that that doesnt have anything to do with this thread....
The reason for the power loss going to a test pipe? Those are turbocharged motors. The slight bump in back pressure from the stock cat/HFC keeps pressure on the seals, making them less likely to blow out.
civicdrivr (07-02-2012)
![Spit](https://acurazine.com/forums/images/smilies/spit.gif)
![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
![Pimp](https://acurazine.com/forums/images/smilies/pimp.gif)
Dspr_02 (07-03-2012)
http://youtu.be/D13gGJ5b_vo?hd=1
http://youtu.be/ECmEU2Zhg8g?hd=1
Here's two old videos of my car when I had, Excelerate performance test pipe and comptech axle back mufflers. Everything else is OEM exhaust.
It only smoked because my tube seals were leaking and I just changed my spark plugs on the dyno before that run so a little oil got into a few cylinders. It burned off fine though lol.
To the OP
Don't remove your cat as it will result in a CEL and you are making the air nastier to breathe....just get a bigger cat if you want a few extra hp but I'd get headers first....
yeah your going to run into a CEL unless u try the defouler trick ( ive never tried it) my test pipe didnt come with an O2 sensor hole...well i guess thats because its actually just a resonator... I just unplugged my secondary 02...car runs fine.
BoricuaTL
04-08-2016 01:08 PM
acurajj
02-14-2016 02:28 PM
IIDXholic
10-08-2015 07:53 AM
