tailpipe
Old 02-21-2001 | 02:30 AM
louisn's Avatar
tailpipe
Yes my right tailpipe is hanging lower than the left. I didn't notice until I read the earlier post. Has anyone had it fixed?? What actually is the fix?? or Are we just getting tooo picky???
[This message has been edited by louisn (edited 02-20-2001).]
Old 02-21-2001 | 04:05 AM
DDT-TypeS's Avatar
6SPDCLS
<font face="Verdana, Arial" size="2">Originally posted by louisn:
</font>
I bought new rubber hangers each for $2.50. Replaced only one on the right muffler side. I believe it's because the right side is heavier than the left. Design flaw. What else!?
By the way, the rubber hanger replaced helped a bit...but I know it'll drape down again after time.
Old 02-21-2001 | 04:26 AM
DDT-TypeS's Avatar
6SPDCLS
</font>
Old 03-20-2001 | 01:00 AM
Buffa's Avatar
Here's an idea I just tried, and I hope it lasts. Buy one of those hose clamps with a screw on the side that adjusts the tightness of the clamp. Wrap the clamp around the rubber pieces that are stretched on the right muffler. The back one will require removing the top post from the rubber piece. Don't try the muffler's post. It's almost impossible to remove out of the rubber. Tighten the clamp until the rubber is about the same length as the left ones. It doesn't fix it perfectly, but it did help! I think there is more of a weld problem that is causing the right one to sag.
Old 03-20-2001 | 01:17 AM
Jens H.'s Avatar
retired
I suggest a prybar to "convince" the various hooks etc to reposition to a location more likely to allow the exhaust to hang correctly.Jens
1992 mazda Miata lowered with Eibach springs KYB AGX adjustable struts Sparco racing buckets 4 point safety harnesses Momo steering wheel lo profile headlite system with PIAA superwhite bulbs Custom audio system Custom gauges Jackson racing supercharger with header and Greddy cat back exhaust and a ton of other stuff 2000 Honda Civic on APEX coilovers Full Alpine Audio system factory fogs with Piaa bulbs Catz ZETA high beam headlamp system H.I.D. Xenon low beam tinted, custom taillites and on and on
Old 03-20-2001 | 02:53 AM
silverESS's Avatar
I am Jack's need 4 SPEED!
it is very sad that we have to do this to our $30K cars--and what ever you do, don't tell the freaks over at IS300.net!!
Old 03-20-2001 | 10:00 PM
revangel's Avatar
i have noticed the same thing on my CL-S. i have talked to my sales rep about it and I WILL MAKE THEM FIX IT! i was behind a black CL-S last Saturday night in downtown SF, and i made sure to look at the car's tailpipes. sure enough, her black cl's tailpipes are perfectly aligned. therefore, this is something that acura needs to fix. just my $0.02. i'll let you guys know once i get it done.
---revangel---
2001 CL-S Satin Silver / Ebony Interior / Navi
CheeseyPoofs McNut
10-11-2015 12:25 PM
DerrickW
20
09-27-2015 03:45 PM
09-17-2015 10:01 PM
09-14-2015 11:09 PM
09-13-2015 02:59 PM
