Taillights..
Taillights..
Im actually looking for the split taillights..(not sure the name)..they have white on top and red on bottom..also looking for suggestions on amount of drop i should use with 17" tl-s wheels i replaced the factory seven spokes with...looks hott!
but i want a drop..keep in mind i live on long island..not very flat round here...thanks yall..
![Lightbulb](https://acurazine.com/forums/images/icons/icon3.gif)
If you have a TL then yes, you can use TL lights. If you have a CL.. then you need the CL lights. They aren't interchangable.
The lights you're referring to are the 2003 CL Tails (clear on top, red on bottom). We carry those if you're interested. SImply go the Acura Accessories section of the CL area of our site.
As for drop... I personally have the H&R Sports drop. I'm originally from NY (Westchester County), and had no problems with that drop. And yes, we carry springs too
![](http://www.c-c-c.net/CustomCarCreations/Cars/CLProductsMain/AcuraAccessories/CL03Taillight.jpg)
<-----You mean these? You can try your local Acura dealer or....Click here!!!
As for a drop, I live in Jersey, and drive in NYC a lot. I have Tein coilovers right now, but had H&R Sport Springs. They are fine. If your car has a lot of miles, you may want to change the struts/shocks as well. So you can either go with coilovers, or use the H&R's with the Koni Yellow struts.
Good luck.
