switching between different brands of synthetic oil
I've been using Mobil 1 since the first oil change, the car has 57K miles. I got Amsoil oil and oil filter at a really good price, is it OK if I run Amsoil one oil change interval, and then go back to Mobil 1?
The reason I am asking is that Amsoil recommends an engine flush before switching to Amsoil from conventional oil. I don't think the same applies when switching between different brands of synthetic oils?
2003 CL-S 6SPD
Im pretty sure that your safe and that you dont need to do a flush between diff types of synth oils. From Synth to conventional its HIGHLY suggested.
From the amsoil website - you should be fine.
"Is there a recommended procedure for changing to AMSOIL Motor oils?
There are no special requirements; however, in older vehicles or those with high mileage, it may be advisable to use AMSOIL Engine Flush first. This will ensure that the engine is clean and free of any accumulated contaminants which might have an effect on the service life of AMSOIL Motor Oils. In all cases, it is good judgement to install a new AMSOIL Absolute Efficiency Oil Filter (EaO) every time you change oil."
I also found this information on Mobil1 site:
Q: Can different synthetic motor oils be mixed together?
A: Mobil 1 is fully compatible with conventional motor oils, semi-synthetic motor oils and other synthetic motor oils, should it be necessary to mix them. However, it is important to note that the superior performance of Mobil 1 will be reduced by diluting it in any way.
Not that I am planing to mix them, but there will be a small residue of Mobil 1 that will mix with Amsoil.... but I guess it shouldn't be a problem either.
I just had to buy Amsoil because it was part of large group buy at a discounted price.
Oil
Im usre once you use Amsoil I am sure you wont use anything else but that!! They have done numerous test on there oil and they say you can get as high as 20k miles between changes!!
mada51589
05-03-2022 08:54 PM
HydrasunGQ
09-14-2015 10:14 PM
asahrts
09-04-2015 05:55 PM
