Swaybar Question for CL-S
Comptech and Eibach make sways for CL-S. Bad
thing about factory are the rubber bushings which allows to much sway. I have just received Eibach sways and springs, and Koni Yellow adjustables. Can hardly wait to find time to install! Cheers!
If you reversed sways by 19 in front and 27 in rear you wouldn't be able to turn car!
We have understeer, so 27f and 19r is correct
configuration. Have received but have yet to install Eibach springs,sways, and Koni Yellow adj. The Koni will help me fine tune car to neutral handling as possible by adjusting a bit firmer in the rear.
By lowering the car wouldn't we put more stress on the suspension and lead to possible early shock wear since most people are not changing the stock shock.
Also wouldn't it lead to more rattles in the car cabin because you will have a stiffer suspension than stock.
Let me know
enjoy the flight
Let me know
enjoy the flight
