Sway Bar Install
Sway Bar Install
This morning i started to do the sway bar install and i had a few problems. I could not move the front end link nuts can be tight. Remove the end link nuts at all and could only move one of the back ones. My problem now is that i think that i could have stripped the other back bolt. Help please!
Mike
Mike
use some wd40
all you have to remove is the endlink nut to the stock sways. they should be pretty easy. you also need a allen wrech to hold the bolt in place or the bolt one get loose
try this place
http://www.cardomain.com/member_page...=184466&page=6
its austin519s site
it should help
sidemarker
try this place
its austin519s site
it should help
sidemarker
I got the rear sway bar in. Inoder to get the bolt off i used another wrench to extend it and that made it easier. Now the problem is that i cannot do it for the front becasue of the limited room. I spayed wd-40 and still cannot get them off. I am going to have another go at it later in the afternoon.
marcelft
07-10-2018 06:17 PM
MonkeyTrucker
09-21-2015 06:15 PM
k6biv
09-10-2015 06:37 PM
