suspension plans, please review
Busy Living
I'm going to do everything all at once. keep in mind i am on a budget, or i'd get Tiens...
sway:just the rear Neuspeed 25mm
shocks:konis yellows, just rear.(upper perch)
springs:comptech front and rear
after everything's settled,alignment and prolly firestone firehawks tires(Zrated).
So, I'm thinking my rear will be pretty damn stiff. I know some are skeptic of the 25mm rear sway, but I believe with the konis and comptech springs, there will be less strain on the brackets.
By keeping the stock front shocks, the ride should be overall forgiving. I'm thinking slightly rougher then with just comptech springs(with rear koni favoring a stiffer setting).
I guess it breaks down to, If your rear konis or set stiff, does it affect your ride comfort drastically.
trying to get a lil V-I
i remember reading that someone had the 25mm Neuspeed rear sways, and ended up busting the bushing mounts because they put too much strain on the bolts. I guess if you do some sort of reinforcing (welding) it was suppose to eliminate the problem.
Busy Living
http://www.tirerack.com/tires/tires....rehawk+SZ50+EP
i guess there are different kinds of firehawks, these are the ones i'm interested in. They got stellar reviews.
Busy Living
as far as brackets breaking, I did see that post, and i am concerned about that. I'm going to see about getting some custom welding done. It's believe that his car was fully loaded, and the wieght was all on one rear wheel. I've heard of 2 TL's with this sway, and one resulted in a broken body mount.
I guess the scenario that would break the mounts is if you had one wheel raised higher then the other ( speed bump, curbs ...)
if you go spring/shock, get all 4 springs and all 4 shocks. no question.
thinking the front will ride better w/ stock shocks is incorrect. no bueno
forget the springs, forget the yellows, forget the rear sway. take the $850 you would have spent on parts and labor and get the teins. then install yourself.
A general and good rule-of-thumb at predicting a tire's performance intention is its treadwear rating. A high treadwear rating almost invariably means not-very-sticky. And somehow I doubt that Firestone would be allowed to one-up its parent company Bridgestone, nor will they suddenly trump serious competitors Michelin, Goodyear, etc. with a superb performer that outshines with both great traction and terrific treadwear. If it indeed had that, I'd think it'd be badged a Bridgestone.
dont reccomend that setup
the car will be too unbalanced. for the price of the neuspeed rear sway you could get comptechs for both front and rear. comptech springs is a good choice and tokico illuminas are good too. also reccomend the neuspeed front tower bar.
im assuming all the parts you have listed will be about 800-900 dollars. thats how much i spent for comptech springs tokico illuminas neuspeed tower bar and comptech sways plus install of the springs and shocks...
sidemarker
sidemarker
What was your goal?
Without having the benefit of what you were trying to achieve, it is difficult to know if this setup will perform as you expect.
On the surface of it, the setup will make the car very prone to oversteer by stiffening the rear in proportion to the front. The ride will be stiffer in the rear. If you intend to autocross the car, this setup may help it turn more since it is likely to snap oversteer when lifting the throttle.
What exactly are your expectations for the modifications?
'Cooter
tell u this...Comptech sways r DEFINITELY better than Neuspeed's...as for the springs/shocks, there r many combo's to choose from as highlighted above...i have the most conservative setup, Comptech springs on stock shocks, and the ride is fairly unintrusive, but u can definitely get a stiffer suspension using coilovers, Koni's, Neuspeed springs, etc....the Neuspeed upperstrut tie bar is IMO worth getting for some extra front stiffness to complement the front sway bar which is fairly thin compared to the rear
Purchased: April 28, 2001
But...to answer's beerknurd's initial question, I can vouch that you DO NOT want to install the 25mm race bar by itself. Unlike Comptech, the Neuspeed front sway bar is COMPLETELY solid to make up for the thick rear bar...although the real question is whether or not you can still even buy the Neuspeed bars, since rumor has it that Neuspeed no longer sell the bars to the general public.
Busy Living
Tahnks for all the replys. Yes, i'm interested in doing some autox'ing, yes I already have the neuspeed. I think igot the last one. They even gave it to me at a discount Under $200 shipped. I would like some oversteer..
sorry so brief, at the inlaws.
joflewbyu2
08-18-2019 10:38 PM
lanechanger
10-13-2015 10:56 AM
