Surging at low RPM - 6MT
Old Jun 26, 2008 | 09:16 AM
goredcar's Avatar
I have had the CL for a couple of years and it has always been a little "surgy" at low RPM in 1st and 2nd. I assumed that this was normal. Recently I had my car in the shop for an alignment and when they drove it for a road test they said that I had a throttle body issue causing the surging.
Does anyone else have this issue with a 6MT?
Old Jun 26, 2008 | 09:37 AM
fuzzy02CLS's Avatar
Dirty/bad IAC valve would cause it. Carbon build up in the TB would as well. What's the mileage?
Old Jun 26, 2008 | 09:50 AM
dru2's Avatar
After switching to 4th gear yesterday I noticed the RPMs jump (3k to 3.5k) with no real speed gain for a split second. It happened a few times after that on other gears.
This was right after I installed the Icebox. This never happened before and I'm driving a 6-speed as well.
Old Jun 26, 2008 | 11:37 AM
rp_guy's Avatar
'03 ABP YA4-S 6MT
could be the dirty/clogged iacv. restart the car and it usually goes away (until you clean it, you gotta live with it)
clutch might be going
Old Jun 26, 2008 | 12:16 PM
goredcar's Avatar
DRU2... this sounds like a clutch problem, but I am surprised that you would notice it in 4th without it also being evident in the low gears.
Fuzzy, mileage on the car is 180Km or 112K miles... what do you recommend I try?
Old Jun 26, 2008 | 02:37 PM
fuzzy02CLS's Avatar
Yeah that's a lot of mileage. Did you get the 100K service done? Timing belt changed?
1st I would clean the carbon out.
Old Jun 26, 2008 | 03:38 PM
goredcar's Avatar
Major service was done at 100K and T belt changed as well. The mileage is all highway. I will look at the throttle body intake to see if it is dirty. I recently changed CAI and didn't see anything obvious. Should I remove the entire throttle body? Where is the IAC valve (and what does it do?)
Thanks for your help
08KBP_VA
Oct 22, 2019 01:55 PM
DerrickW
Nov 15, 2015 05:52 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
Matthew Purpura
Sep 25, 2015 06:10 PM
Rcelestino93
Sep 23, 2015 10:01 PM
