Supercharger Thoughts
#243
The boost has not changed. With the IMRC off 7.5 psi, when it was on, it was 6.5 psi.
I went back out to re-torque the header bolts an hour after the initial test run,.... the intake manifold was stil very, very, hot. The Swain coating was cold to the touch!
#246
Originally posted by ModAddict
The Headers are on
took the IMRC control off and put it up on the shelf.
The Headers are on
![Cool](https://acurazine.com/forums/images/smilies/cool.gif)
Cool... about time you got that done..... TAKE ANY EXHAUST MEASUREMENTS??..... I got mine... PM me with yours so we can order these dumps this week...
I am sure by you taking off the IMRC it made it easier for you to get to the rear bank on the headers too...LOL..I still have not unplugged mine yet...
awaiting your PM
Smitty
#247
#248
I'm going to pass on the dump for now. Where did you end up with the brakes? pm if you want
:thumbsdn: what the hell do I got to PM you for then?..
![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
I got all the measurements and even test fit the dump... no clearance issues or anything.. it is pretty straight forward, I will e-mail everything tonight and he will get started next week.
Smitty
#250
Got the Rotora 4 piston with new pads for the front & rear, matching rear slotted rotors, SS lines and 5mm spacers for when I put the stock rims back on in the winter...
The guy from Wilwood would not budge on price he offered them for 1700 plus shipping...(1743 total)(took off a whole 50 bucks)..(fook that)... So my money went to Baty and I got the ROTORA kit.. he will have something up for the board after I do the install next weekend..
#251
17 inches of sweetness at the flick of a switch...
The test fit looks real good... I am e-mail the dimensions to DMH performance now...
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
#252
The 2 flanges that he will supply for me to tach weld on so they are PERFECT... since if they are off 10 degrees it will screw everything up... Once I have it all done he will have it ready as a direct bolt on..
#253
Okey dough key...
got the Polished Pulley from Essarak Huot today...
I am pretty sure I have the address saved on my othe CPU..
Brad you need to call him first and let him know what is going on before I send this awesome looking pulley in???
I will snap some pics later...looks tight..
Smitty
Smitty
#255
Originally posted by scalbert
OK, I ran some of the numbers on the two pulleys in question. We already know the following sizes of SC drive portion of the alternator pulleys:
3.000 Inch for the Standard Pulley
3.275 Inch for the Higher Boost Pulley
As we discussed, from here it might be better to swap the SC pulley to get even more boost. The standard SC pulley measures about 3.92 inches. The following are estimated sizes and their associated boost levels for the SC pulley.
3.6 Inch should generate about 7.5 PSI boost
3.5 Inch should run it up to about 8.0 PSI boost.
Now all we need to do is send off out SC drive pulley to get copied and a smaller one made. Hopefully just in time for the completion of the intercooler.
#256
#257
I see you found the post two pages back.
This was assuming the higher boost alternator was already installed. IMO, this is the combination which should be run in order to retain the same belt.
#258
But I would hold off on the pulley fabrication for the time being. It would be fine to send it to them to take measurements, etc. But we do not know what the boost will do with the new manifold.
I'm actually thinking it might drop the boost some from what we are seeing. But we'll have to see about that though. I hope to have it on the car within two weeks. At that point we can be sure about what size to have them make.
#259
#260
#261
Interesting how this thread started five days before my girls were born and it is still going strong. It is coming up on two months old now...
#264
Are the
's sleaping thru the night yet?
Are the
![Baby](https://acurazine.com/forums/images/smilies/baby.gif)
But I keep hearing that it will get easier soon.
#265
Did you get the core yet?
#266
I'm lucky if they sleep four hours at a time. Most of the time they wake every 2 - 3 hours and want to feed. Compile this with Jennifer nursing and we are doing well to get 4 - 5 hours sleep in a night.
#267
Yea, the doctors say to wait until 4 - 6 months but we plan on starting them at 3 months. I have yet to find a compelling argument and evidence as to why they can't start cereal sooner.
So we plan on getting them going ASAP as we can't survive much longer like this.
4.5 weeks and counting and I assume we may start weaning it in sooner than that.
#268
Just thought of something,...
,....I took the IMRC off and there is a nice bracket attached to it that might be able to be used to support the IC at the back fo the engine.
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
#269
Yep, I was going to look at that when it was in place. At a minimum the mounting points could be used which is what I suspect will happen.
#270
#271
Censored User
Location: Miami - just one day, I would like to drive without getting cut off!
#272
Oh my.. after seeing this piece I want to tear my charger apart and spend the 500 bucks at the Harley dealership that Essarack Huot went to and get mine done.....
.... damn does this look good....
Got your e-mail Brad.. I printed everything out and it will accompany the pulley to Terry tomorrow..![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
Essarack has a ways to go on his project car, but I told him I would get this back to him ASAP, so I am sure Terry understands...
Smitty
Smitty
#273
Essarack has a was to go on his project car, but I told him I would get this back to him ASAP, so I am sure Terry understands...
Smitty
Smitty
![Big Eek](https://acurazine.com/forums/images/smilies/bigeek.gif)
#274
Originally posted by JaDia4
To all of you guys - So when you get to your final setup are you going to post what you ended up with and the dyno results. And will you be helping other SC owners get a similar setup to maximize their output.
Don't ask stupid questions...You should know better than that. We are not like other people who did upgrades months ago and Mystery Mods 1 & 2 and tease people about what they could get.... No one was born knowing everything, we all learn new things each and everyday... but people like that will rott in hell and I will make sure I send them there.!!!!...
So now that I finally got that off my chest... lets stick to the topic at hand....
#277
#278
![Drool](https://acurazine.com/forums/images/smilies/drool.gif)
I now know my future but I don't know about $500. I think I'll plan a weekend and do it myself...
#279
The Max Boost Stepper Pulley is made of lightweight aluminum, and incorporates a unique groove design to eliminate belt slippage at high boost, track tested at 12 psi on a Paxton blown NSX. Estimated boost on a Comptech S/C kit, for the Acura 3.2 CLS/TLS is 8 psi. Actual boost numbers could vary from car to car. Not recommended without an intercooler, such as the "Type S/C"
...in case the link does not work,.... http://www.photohost.org/gallery/sho...hp?photo=16324
#280
I don't recall the exact offset, but the stock unit and Comptech unit did have an offset ring where it contacted the alternator. This may or may not be an issue but I can't remember if this was needed to clear part of the alternator.
Also, is that the higher boost Comptech pulley?? It looks larger than stock.
![](http://www.flwse.com/images/steve/ComptechSC/565Max_vs_Stock-med.jpeg)
