Supercharger Question
The livin's easy
From what i understand no. Im sure you will get a much better explanation why but heres my thought. A turbo has to spool up to force pressure into the engine. The blow off valves have two main purposes 1.Sound cool 2.Prevent boost leakage. Supercharger's work differently by using a belt to constantly pump boost into the engine. So im guessing since the supercharger is using a belt there is no loss in boost? meaning a blow off valve would be pointless. Just tryin to help sorry if its not rite .
Not on the positive displacement blower on the Comptech kit. The blower is after the throttle body negating the need for a BOV.
The reason for a BOV is to elimintae compressor surge. That is when you are under boost and close the throttle. The boost that is in the intake plumbing before the TB wants to equalize with the ambient air. The only way out is back through the compressor. This causes cavitation of the compressor wheel which damages the bearings over the long run.
IT IS NOT JUST FOR SOUND!!!
With all of this in mind, yes, a BOV can be added to a supercharged system. But only to a centrifugal unit which is almost always placed prior to the TB. The Comptech blower is a roots style which is installed after the TB.
Also, the Comptech blower does use something similar; a bypass valve. It opens with vacuum and reroutes excess flow back around to the inlet of the blower. But not to atmosphere as this is still under vacuum and only intended to smooth the blower operation under vacuum.
Originally Posted by mrimage27
Can you run it with the bypass valve, or you have to disconnect the bypass valve?
Adventurist.
Though adding the BOV is a possibility, on the CT S/C, there would be no gains, possibly losses as steve said.
With the use of the BV/DV, correct me if I'm wrong, but that amount of pressure is needed to run things smoothly, hence, the reason the roots shouldn't release pressure into the atmoshphere.
navtool.com
31
11-16-2015 08:30 PM
lanechanger
10-13-2015 10:56 AM
navtool.com
09-25-2015 05:15 PM
