Supercharger problems and questions (video included)
I bought a used supercharger recently and installed it this weekend. I took my time and did everything carefully (belt tension, soldered ESM, etc). Driving it, I feel a hesitation as the RPMs rise up. Usually around 3k or so and another hesitation before 5k. Like I have turbo lag or something.
I slapped on some gauges temporary (waiting for my gaugepods) and fuel pressure is slightly under 40lbs at idle and vacuum is around 20. If I rev the engine, my revs drop when it hits 6k like I'm hitting the rev limiter. Looks like something is cutting off fuel? Here is a video with the fuel pressure gauge and tach in sight and another video with the boost gauge.
A couple questions:
Any idea why this is happening?
Am I supposed to hear the sc whine reving it like that?
Should I see boost reving it in neutral (I see around 2.5-3 if I start accelerating in WOT).
The blower also sounds like a bunch of marbles at idle. I know there is some noise but I've never heard another SC'd CL so I don't know what is normal.
Any suggestions?
Thanks a bunch.
A couple questions:
Any suggestions?
Thanks a bunch.
congrats on the install and good job doing it yourself. I use to have a SC and mine sounded like a bunch of marbles at idle as well, sounds normal. your suppose to hear the whine whenever you rev it. as for the revs dropping off while your revving it in neutral, that's normal as well, the ecu won't let you rev it in neutral to high rpm's. some people say it won't let you rev it past 5000rpm, i don't know, never tried it, never had to, never wanted to. fuel pressure seems right, if you get a little detonation at the top of the gear, you might want to add a few pounds of pressure, say to 40-42 psi at idle, and that may help drown it out. don't know about the hesitation your experiencing and it's hard to diagnos with the info you gave.
Nothing out of the ordinary IMO.
I ddin't watch your video but here's a video of my car at idle with the hood open. Sounds like a can of dried peas tumbling around.
http://photos.imageevent.com/mrsteve...51009_0001.AVI
Originally Posted by cltypeSLOW
does the SC kit really run that low of boost? i thought it was like 5 psi or somethin?
Blown is Best
Congrats on your SC and personal install
The only suggestion I can offer is to double check hoses, vacuum lines, and electrical connections. If you don't have any luck working through it, it may be worth a trip to Comptech and have them double check your install.
I did that with mine after I installed just for a piece of mind.
I'm having a hard time seeing the hesitation, not that it's not there, but can't see it/hear it. it sounds smooth to me overall. also looks like your getting a 1/2 lb boost drop at the upper rpm, check the belt again, they do slip. another thing i'd look at changing is your max fuel pressure. it looks like you are pushing well over 100psi. I think the potential is there to lock up an injector at that level, but depends on how far over 100 it's seeing. I honestly believe you could drop that to 80-90 psi safely. you have to change the disk and spring in the fpr. nice vids.
Thanks for the responses everyone. I'll go over everything again today and maybe I'll make an appointment with Comptech to double check everything. ThinJim, you mentioned that my fuel pressure at WOT is a bit too high... I've read that fuel pressure should slightly over 100 psi. I'll check with Comptech though.
oh wow i know nothing
get you a HBP ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
Originally Posted by mytran
Mine came with the HBP too (bought it used) but I'll never put it on because we have 91 octane gas here.
![Agree](https://acurazine.com/forums/images/smilies/agree.gif)
Especially double check the ESM connections. The connections need to be soldered, not crimped. I had issues with my SC install and took my car into CT. Afterwards... no worries.
321 whp SAE
check your A/F ratio.. tells you a lot that's the gauge to invest in.. i had a fuel pressure problem with my charger at first.. AEM uego is my recommendation. my boost also has a similiar drop at the high end.. don't think it's belt slippage.. you would hear a terrible noise if your belt was slipping.. a nice screetch
Mytran could you take a picture of were you installed the sender unit for the fp gauge under the hood. And also were you installed the constant power for it. Thanks.
![](http://www.mytran.com/gallery/download/18695-1/IMG_0310.jpg)
I used the two fittings mentioned in this thread: http://www.acura-cl.com/forums/showthread.php?t=167289
For power, I tapped it from fuse #9 on the driver side fuse box. This is for the instrument lights/memory seats and power comes on when the key is in the ON position. I was lazy and wrapped some wire on the right leg of the fuse and plugged it in. I'll trace through and find a better tap for it later. As for the lights, I grabbed it from the dimmer switch (the black & black/red wire). You can use other switches like the cruise control or sunroof switch but they're harder to get to.
Just an update... I tested my ESM voltage and it was at 2.97v. Not sure why it was that high... maybe the previous owner changed it. I backed it back down to the standard 2.93v and it runs great. No more hesitation and the thing pulls like a mofo. In 1st gear, my tires are slipping/screeching over the last 1.5k of the rev band. I thought my check engine like would come up with the ESM set that high. Oh well, it works now
![Cheers](https://acurazine.com/forums/images/smilies/cheers.gif)
Glad to hear that you got the problem corrected. When other told you that the hesitation was normal, I was quite surprised.
Originally Posted by ThinJim
If I may make a suggestion...although it may work or appear to be working fine, the autometer boost gauge is tempormental to volt changes while cranking your car. It needs to have an uninterupted source of power while the car is cranking. Under the drivers side dash is a very fat yellow wire with a black stripe, comes out of the distribution/fuse block. this feeds juice to the ignition switch. I spliced into this wire (peel away a portion of the insulation, do not cut wire) for the autometer boost gauge. On a side note, i always turn the key to the on position and wait a few seconds so the boost gauge calibrates itself. I think you'll have more consistant results with this setup.
Drinking Beer In
Did you mean to say the red and the red/black wires (for dimmable lighting of the guages)? The reason I ask is that I just spent last Sunday laying across the door sill hooking up guages,
Originally Posted by hemhaw
Mytran -
and that's where I went.... I picked it off the VSA switch, because it was handy and had a light in it. Werked Gud ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
I'm a Vagiterian.
Nice job on everything! Glad to see you did it yourself. I bet you'd have more fun if you can get the HBP on and get it tuned. That, or just keep getting some octane booster.
![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
how loud is everones "marble sound"??
mine sounds absolutely terrible and im not sure if the SC is bad or its normal... and i cant really tell off of steve's video as it is just.. a video
Drinking Beer In
Mine's not horrible at idle... Sounds like a bad AC compressor bearing. Yours is turning faster than mine at idle, though.
But it sure sounds sweet when I get on it!
My gas mileage has gone to hell. I suspect this has less to do with the SC and more to do with me nailing it everytime I get a chance.
what happens if the fuel pressure isnt adjusted correctly in accordance with the high boost pulley?
will i be losing power as well?
also, is the whine noticable throughout all rpms?
thanks
thanks
