supercharger checklists
looking for the comptech supercharger parts checklist for 2003 cls 6speed and 2000 honda accord. anyone have them handy?
or if anyone knows for sure which part/parts i need to make a sc for 2000 accord work on my 2003 cls 6mt. thanks in advance
Blown is Best
Here's a link to the checkoff sheet from my CL-S6 kit:
right click the link below and "Save Target As"
http://photos.imageevent.com/allout/..._Checklist.pdf
Si Vis Pacem, Para Bellum
you're probly gonna need a different elbow as well. the SC i got from siggy came with an accord elbow but IIRC it's way different then the CLS6 elbow. $200 part from comptech.
.. V-6 Accord General Parts Kit (355-203)
. Washer Bolt (6x14mm) 800-2002H
Fuel Pump 360-010
. Battery Box 355-124A
. Battery Hold Down 710-050CLR
. Flange Bolt (6x75mm) 800-2011
. Radiator Overflow Bottle 355-126
. Upper Radiator Hose 355-155
. P/S resevoir bracket 355-128
. ESM Unit V6 -preset to 2.8v 340-055
. Adj. Bobbin Bolt (10 x 40mm) 800-4017
. (2) Cam Seal Bolts (8 x 30mm) 800-3006
. Cam Seal O-Ring 805-022
. EGR Valve Gasket 805-027
. (2) Throttle Body Gaskets 900-970
. (6) Denso IK 22 Spark Plugs 806-040
.. Icebox Kit 300-130
. Elbow with vent hose (plastic) 300-054-2
. 3” to 2.5” rubber flex bellows 811-029
.. Fuel System Adapter Kit (355-204)
. 12mm to –6AN Adapter w/ Washer 813-005
. Push-on Hose End (-4AN) 814-308
. Return Hose (5/16” x 7.5”) 811-001-7.5”
. (2) Fuel Line Hose Clamp 812-009
.. V-6 Accord Hose Kit (355-205)
. Coolant Bottle Hose (5/16” x 10”) 811-001-10”
. T/B Water Line (5/16” x 10.5”) 811-001-10.5”
. T/B Water Line (5/16” x 17”) 811-001-17”
. Bypass Valve Vacuum Line (3.5mm x 6.5”) 811-002-6.5”
. FPR Vacuum Line (3.5mm x 9”) 811-002-9”
. Valve Cover Vent Hose (1/2” x 19”) 811-020-19”
.. V-6 Accord Sub-kit - Select one:
. For ‘98 - ’99 Accord: (355-207)
. Fuel line (816-013)
. Push-on Hose –6 Black (24”) 814-323-24”
. Push-on Hose End (45° -6) 814-324
. Push-on Hose End (90° -6) 814-322
. T/B to Air Assist vacuum line (3.5mm x 20”) 811-002-20”
. For ‘00 - “02 Accord: (816-014)
. Push-on Hose -6 Black 12” 814-323-12”
. (2) Push-on Hose End (-6 90°) 814-322
.. V-6 Accord Document Kit (355-206)
. Instructions -ESM INS-091
. Instructions -Accord S/C INS-094
. CARB Sticker 730-116
. Warranty Card 099-Warranty
. (2) CTE Decals (Small) 730-109
Revised 02/27/08 nh
Fuel Pump 360-010
Revised 02/27/08 nh
BoricuaTL
04-08-2016 01:08 PM
Joe Avesyan
09-29-2015 03:57 PM
