Stone Headers: Please do NOT install before reading this post.
#161
Originally posted by Shawn S
I think this “STONE” place hired all the workers that were fired from OBX for fawkin-off on the job.
Shawn S
Shawn S
#163
Mr , do you mean the hole like in the picture above or the actual port itself?
For the holes, if you have mis-alignment you can bore out the lower hole as shown above.
For the actual port itself, if there is no sharp edges, no need to do anything.
Nashua.
Nashua.
#164
I just wanted to tell nashua that he's doing an awesome job for the help and the response time that he replys to my pm's and just how helpful he is . I know it's very stressful and what not but nashua keep up the good work
#165
Originally posted by fender4
Someone will be getting two fronts,,, I double checked mine before ,after,during, and after removal, and again now NOPE I have the correct pipes,, still need that comptech parrallel measurements,,,
#167
More succesfull installation of Stone Racing Headers: http://www.v6performance.net/forums/...?threadid=9781
#170
Originally posted by bullaculla
Hey Nashua, if you look in my headers thread on page three, I measured my headers too.
#172
Originally posted by DOLEFEE
Nashua, I just took pictures of the "identical" headers. However, I can not post pics. Would anyone like to host them for me? Let me know so I can e-mail the pics...
#174
#177
For your reference, the headers are very close in design. Here are the original pictures:
http://www.acura-cl.com/forums/showt...aders+pictures
#179
Nashua, I have been staring at my headers for like 4 min. straight...I honestly cannot tell a difference. Do you have any pics of the headers side by side? Or could you tell me where to specifically look (ie.. which flange, etc..) for the change between the two headers?
#180
Put the flanges on a flat table, the headers up right, if you look from the side, one is angled and on is upright.
Sorry, I do not have headers at hand. Maybe BRCLS will post pictures.
Do not worry, if you have identical headers we will ship you the one missing.
Nashua.
Nashua.
#185
ModAddict,
It was stated from day 1, that those header does NOT come with a stated warranty. However, I am doing my best to accomdated each issue on one-by-one basis.
Nashua.
Nashua.
#188
Originally posted by Nashua_Night_Hawk
ModAddict,
Nashua.
ModAddict,
Nashua.
I'm a little suprised Stone Racing does not warranty their products! That is not a very confident statement to the aftermarket community.
#189
I believe I asked this before probably in a PM, but I only asked if gaskets are included with the Stone Headers and I got a reply of yes, but which gaskets are included?
Using the picture posted above which gaskets are included?
ALL gaskets?
Gasket on Flange 1 ?
Gasket on Flange 2 ?
Gasket on Flange 3 ?
Gasket on Flange 4 ?
Gasket on Flange 5 ?
I see by the picture above that the OBX's come with gaskets on flanges 4 & 5. Can't tell from the picture about the other flanges.
Thanks,
Jim
ALL gaskets?
Thanks,
Jim
#190
Originally posted by ModAddict
I'm confident I can get the headers on the car, but I'm not confident I can do so without cracking the Swain coating. If that happens, then what?
One thing, I hope swain does not mix front and rear headers and ship you the wrong headers. Pleas email your contact at swain and let them be careful.
Nashua.
#191
ALL gaskets?
Thanks,
Jim
ALL gaskets?
Thanks,
Jim
All 5 flanges, 2 gaskets for flanges 4 & 5 and 3 O-ring for 1, 2, and 3.
Nashua
#193
OK..below is a bunch of pics showing my most probable "duplicate" headers. In the first three pics you see one bolt going in the same location of each of the two headers. I felt maybe there was a manufacturing bug or maybe I was lucky to have DIFFERENT headers as the bolt could only be inserted in one flange and not the other. The bolt simply would not fit in the hole. I figured out that maybe I put the bolt in the wrong direction (I had the nut underneath the bolt) and changed the direction to have them all fit.
The next four pics show each setup of the headers (w/ flanges swapped) and pretty much show identical setups. The pics prove I most probably have two REARs because of the angle the flange on the front postion is at.
The next two pics show what I hope is the correct way to bolt the headers down (nut on top ) and for the gap size I was wondering if this is normal gap for hand-torqued
Last two pics reinforce what I mentioned earlier about the angle of the front mounted flange.
#197
AgentDSS,
Please put the headers side-by-side, both upright. if you look from the side,you should see one slanted one up right. If both are uprights, then you have rear headers. If both are slanted you have fronts.
If you have only rears or fronts, we will ship the missing one.
Nashua.
Nashua.
#198
They finally sent me late on Friday when I asked to have it delivered in the morning. That a different story.. I got them installed on Saturday and I drove around for a while and they were all good. Turned off my car went and did something came out and started it up and drove around and then noticed my engine light was on and still is... What do you think it could be.
