Stock air box broken, help!
Old Aug 18, 2005 | 11:53 AM
Koreets.RU's Avatar
AKYPA Owner
Unhappy Stock air box broken, help!
hey guys!
that damn mechanic broke one of plastic straps which holds the upper part of the box. I tried to tight it as much as I can but it still a lilbit lose.
do u guys think it might be a problem? anyone had the same? is there any way to fix it or should I buy a new part? or maybe get a Icebox instead?
thanx in advance
Old Aug 18, 2005 | 11:59 AM
zoltanh's Avatar
I need a Hybrid CL-S
get any icebox instead, problem solved.
Old Aug 18, 2005 | 12:07 PM
Smitty's Avatar
get an icebox and give the mechanic the receipt.
Old Aug 18, 2005 | 12:20 PM
phipark's Avatar
Not Asian
Defintely don't buy a new stock airbox. Might as well get the Icebox. Did you bring this to the attention of the mechanic?
Old Aug 18, 2005 | 01:00 PM
Koreets.RU's Avatar
AKYPA Owner
thanx guys for quick reply
i tried to talk to the guy but he said he had nothing to to with that
so f*ck him don't have a time to deal with that now
how is fuel efficiency with the Icebox?
is there reasonable hrsp and torque increase?
thnx again
Old Aug 18, 2005 | 01:13 PM
Smitty's Avatar
search is your best friend...
in a nut shell:.... what you think a gas pedal is, is NOT.. it is an air pedal.. when you press the so-called gas pedal, your opening up the throttle plate with lets more air into the intake manifold and into the runners.. from there air & fuel mix in the chamber to produce combustion from a spark.
When you have a restrictive Stock air filter and press the air pedal (aka gas pedal) the response time and air flow is reduced... with the air box, air flow is increased and is less restrictive which lets more air flow easier through the omni foam filter.
so .. the air box is great... and there are small HP gains..
Old Aug 18, 2005 | 09:13 PM
bladas's Avatar
Lightbulb
I was replacing a stock air filter with a K&N air filter and broke one of the two plastic loops on the air cleaner housing. On one side their are screws on the other side their are two plastic loops you have to try to see as you fit the top back on.
I found the broken piece down in the engine bay, tried to super glue it back but it wasn't a clean break so that didn't work. What is working is a small paper clamp (you squeeze the clamp handles to open the clamp lips). It looks bogus but the clamp is holding the top and bottom halves of the air cleaner housing together.
Old Aug 19, 2005 | 12:17 AM
Koreets.RU's Avatar
AKYPA Owner
thanx for hint bladas!
Old Aug 19, 2005 | 08:24 AM
RaviNJCLs's Avatar
Icebox. That's my recommendation too.
Old Aug 19, 2005 | 03:30 PM
berny's Avatar
I need FI
if you got the money together, icebox is efficient on fuel and hp gains
Old Aug 19, 2005 | 04:39 PM
dfv3.2CL-S's Avatar
I have a stock airbox available since I SC'er my Cl-S about a month ago.
Old Aug 20, 2005 | 12:56 AM
Koreets.RU's Avatar
AKYPA Owner
sent pm to dfv3.2CL-S
Old Aug 20, 2005 | 02:43 PM
dfv3.2CL-S's Avatar
YGPM today
drone619
Jan 26, 2016 07:09 PM
Kevin Sami
Sep 22, 2015 09:59 AM
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
Abe_Froman
Sep 16, 2015 01:27 PM
bymotion
Aug 31, 2015 05:00 PM
