SRS/OPDS Help
SRS/OPDS Help
So, my SRS light had been on, tried to reset but no luck, came back on. Took it to the dealer. Dealer (Radley Acura in Falls Church VA) says OPDS sensor needs to be replaced. Total cost $660.
I searched the forum, but just want to double check that this should not be covered by my Acura extended warranty. Also, in my searches, seems everyone else was being in the $300's. Anyone get it replaced under warranty? If not, how much should this cost?
Appreciate all the help, as always.
Back to Four Doors
As for the extended warranty, the dealer tried to tell me the OPDS sensor WAS NOT covered. But if you read the warrany coverage on the back of the contract, I cannot possibly see where it WOULD NOT be covered.
Back to Four Doors
Yea, I had tested my battery, found it would not hold a charge, and replaced it. SRS sensor came back on as soon as I started the engine.
If I have the dealer reset the light and there is a problem with the sensor, how long till it comes back on? Instantly? 3 miles?
Anyone have to pay to have the sensor replaced? Cost?
Bleed Honda Blue
Oh, I should asked what is the SRS code?
Originally Posted by sgmotoring
Before you replace the sensor, try to initialize the opds sensor. If you have a TV monitor or cell phone charger on or near the seats, you should remove that too.
Anyone know how much it should cost to replace the sensor? Dealer tells me $595. Says the part is $412 alone. Anywhere to get this done besides the dealer? A Honda dealer perhaps?
Bleed Honda Blue
Dealer says the code is "15-3 OPDS System Failure". Initialize the system? Not sure what you mean.
OPDS bulletin info
The info at this site should answer some of the posted questions:
http://www.vtec.net/forums/one-messa...&page_number=1
--Ollie
--Ollie
