Squeaky CT sways or bad stock strut???
Old Aug 14, 2003 | 09:30 AM
Speed_Racer's Avatar
6 Forward 1 Back
I'm hearing a squeak in the rear when I go over speed bumps. How do I know it's not bad struts vs unlubed sway connections?
Do bad struts squeak? I can push up and down on the rear bumper and hear the squeaking.
Old Aug 14, 2003 | 09:31 AM
Scooter's Avatar
'Cooter
most likely the sways...get some car grease that's NOT water-based and have em relubed
happened to me and a bunch of other people on here as well
Old Aug 14, 2003 | 09:53 AM
NSX-Tuner's Avatar
boosted is best
I've had CT sway on for at least 4k miles. The rear sway polyurethane bushing speaks like a mother and requires regular lubing or teflon taping. However, CT has replacement hard rubber bushings available to eliminate this problem. Also, I doubt it's your rear shocks.
Old Aug 14, 2003 | 10:32 AM
6 Forward 1 Back
Thanks guys. I should do a search, but I'm feeling lazy. Can I lube the sways by just jacking the rear up and applying it. Or do I have to unscrew the bushings?
Old Aug 14, 2003 | 10:36 AM
tmk70's Avatar
Masshole
I had that issue too.....get some lube.
Old Aug 14, 2003 | 11:21 AM
Ray Khan's Avatar
a bad strut is easy to check for...push on a corner of the car that is good and gauge the rebound...then go the corner you think is bad and push...if it bounces a lot before settling..bad shock.
The chirping could also be your brakes.
marcelft
Jul 10, 2018 06:17 PM
drone619
Jan 26, 2016 07:09 PM
o8 ENVII 8o
Nov 30, 2015 04:23 PM
mugen_kid
Nov 13, 2015 10:38 PM
MonkeyTrucker
Sep 21, 2015 06:15 PM
