specs for cl-p
1 Post
i don't think there is such a thing as "hard definite specs" considering every stat recorded were done so under different conditions, so the most definite is the average.
if you find 6.7, 7.1, 7.5, etc. i'd say probably around low 7's, but there's no definite answer...like if you get one and it does it in 7.7 and you saw it listed as 6.7 somewhere, you can't get a refund.
like the cl-s is probably 6.6 average, with some lower (6.4) and some higher (6.8).
Moderator Alumnus
The CL-P has the same engine.transmission as the 2000-2001 TL. 225hp etc..
The TL has published 0-60 times of 6.7 - 7.1 sec. Therefore you should expcect similar results for the CL-P.
I remember seeing someone on this board do an unoffical stock CL-P 0-60 test and if I remember he got about 6.9-7.0 each time. Or abour .4 sec off the Type-S.
2001 Silver CL-P
PIAA 19224
Hiper 9005
Eibach Pro-Kit
Tinted
2001 Silver CL-P
PIAA 19224
Hiper 9005
Eibach Pro-Kit
Tinted
emailnatec
29
09-28-2018 04:27 PM
4drviper
09-23-2015 07:42 PM
