Spare Tire Pressure?
Originally posted by John*K
That's the thing -- it says 60 psi, but that seems like a lot for the spare.
Administrator Alumnus
It should tell you right on the inside of the driver's door what it should be set at. Look for it with the other tire pressures that are listed...
![Doh](https://acurazine.com/forums/images/smilies/doh.gif)
It also loses pressure more quickly than you'd think. I check it every few months in both my cars, and it is usually down to 45 psi or so, though I set it to 60 every time.
What does oen do if they have 18" rims and you get a flat? My aftermarket tires are 215/40/18 but my stock spare tire is a little bigger. Do i need to get a new spare or can I use this one for a short time to get to the garage?
Originally posted by spdy0001
The diffrence is so small that you won't have a problem using your spare for a short time till you can fix your other tire
Go with 225/40 or 235/40 for a closer diameter to stock.
Shawn S
Shawn,
Thanks for the input. Yeh I'm not too thrilled withthe 215s, but I got such a good deal on my RH C5's wit hthese tires and it seemed liek such a shame to throw them away. So I figured I would use them for sometime before gettin new wheels...
My one question is why would the 215 be any different then 225 or 235, isn't the difference simply in width not in height? I thought as long as they were 40 it was the same thing?
The “40” means that the sidewall is 40 PERCENT of the tire WIDTH.
Wider tire means higher sidewall means larger diameter.
You could also go to a 215/45 for the same effect.
damnit, that means I misunderstood that whole 40 thing. Goddamnit!!! Do you think I need to switch my tires soon or is it safe to use these up and then switch to 225 or 235?
CostcoFanAUS
09-18-2015 06:05 AM
