so im looking for more power...am i at the end of the na spectrum?
Old 08-20-2005, 09:48 PM
typeR's Avatar
im thinking i might have to pull these heads and give them a street port? mabye the cams while im at it? but before i do are there any other more affordable mods i should look at...EGR bypass? maybe the B pipe? i need 20+ hp
Old 08-20-2005, 11:16 PM
CleanCL's Avatar
i just installed the bpipe and i would guess you gain about 5 whp from it, it's expensive, but i was looking for about all the boltons possible on top of a difference in sound which i accomplished
if i were you, i would look into seeing how far you can p/p the heads
also a high flow cat would yield SOME gains, but through all my research i have heard of very few doing it and those that did never reported track times/dynos, but in my experience, hiflow cats always yielded gains throughout the powerband rather than a delete pipe, also the hiflow cat is legal
when it's all said and done, why not contact unichip and find a local tuner, i'm sure they can muster up 10+ whp for you as well to bring your trap up 1 mph
i keep looking at your posts and am staying NA almost entirely because of you, keep it coming, cheers.
Old 08-20-2005, 11:17 PM
Mike's Avatar
what gains do you anticipate from the exhaust?
Old 08-21-2005, 01:58 AM
allmotor_2000's Avatar
Without rebuilding the motor or other experiemental stuff (like cams, p&p the heads etc.) your best bet is to tune your power-curve to suit your tranny gear ratios and general car-setup at the track.
First step there is to go get a dyno. I have some software that analyzes your power-curve to other parameters including wheel weight, diameter (at start and after the 1/8-mile), car weight, gearing, elevation etc, etc.
Old 08-21-2005, 09:42 AM
typeR's Avatar
i should dyno this week...ill let you know...
Old 08-21-2005, 12:01 PM
GEEZER
1killercls's Avatar
Received 2,214 Likes on 1,418 Posts
nawz!
Old 08-21-2005, 12:29 PM
johntypes's Avatar
type R I lost HP porting and polishing my heads,and b-pipe gave me 3.8 hp but I do not have a S/C which will make a diffrence, good luck let us known
Old 08-21-2005, 04:28 PM
typeR's Avatar
i dont have a super charger either?
Old 08-21-2005, 04:41 PM
johntypes's Avatar
I just noticed your a 6 speed saw those # and that is the first thing I thought.
John
Old 08-21-2005, 05:02 PM
mister D
kHmER Co's Avatar
John
He doesn't have a 6 speed either
Old 08-21-2005, 05:29 PM
I'm a Vagiterian.
All Mine's Avatar
Yeah he does.
Old 08-21-2005, 07:42 PM
Relax!
6MTpromises's Avatar
no he doesnt, read his sig closer. Its an '01 (no six speed), he has the Ice box for the six speed. Maybe it fits better with the 3.5 block?
Old 08-21-2005, 07:50 PM
mclarenf3387's Avatar
He has the 6 speed Ice Box cause he got rid of the VSA throtle body.
Old 08-21-2005, 08:34 PM
typeR's Avatar
ding ...ding ...ding...we have a winner
Old 08-21-2005, 08:48 PM
The scary part is I knew that without even looking at your sig.
I think its a sign of spending to much time here when you start to memerize members mod lists
Old 08-21-2005, 08:51 PM
typeR's Avatar
frickin sig also says VSA delet,and im surprised someone like john doesnt know...
Old 08-21-2005, 09:46 PM
Dagreen's Avatar
port polish will help some if you dont have them over bore, cams will be a good combo,but if your going to s/c then a over bore on the head will flow much better that will give you the power you need.
Old 08-21-2005, 10:23 PM
mister D
kHmER Co's Avatar
Originally Posted by All Mine
Yeah he does.
noob
Old 08-22-2005, 12:26 PM
nothing
bryanz3.0cl's Avatar
go for cams, give endyn a call or webcam. you could gain alot esp since youre still running stock ones
Old 08-22-2005, 01:49 PM
I'm a Vagiterian.
All Mine's Avatar
Originally Posted by kHmER Co
noob
Not soo much that I'm a noob, just that I didn't read well enough.
Old 08-22-2005, 02:16 PM
highroller's Avatar
I had a good engineer friend at Omron Engineering help me with my Uni-chip set up. But I find most of my gains were in the suspension hook up. Although I am running a 6speed, a different animal.
Old 08-22-2005, 02:22 PM
ASM I.S. Design FTW.
brianlin87's Avatar
or that you can't read period. :troutslap
Old 08-22-2005, 03:15 PM
Never had a clean run
rtatsutani's Avatar
What suspension do you have? You set it up in a special way? You runnin some damn quick quarters with just the basic boltons and uni chip!
PS, what tire/rim combo you got too?
Old 08-22-2005, 03:22 PM
Relax!
Yeah....those are some impressive NA numbers.
Old 08-22-2005, 03:45 PM
Read people He has a 3.5L swap which is putting him more on par of supercharged CLs.
Old 08-22-2005, 03:59 PM
I now drive an accord....
spdy0001's Avatar
Man the education in this country is going downhill
More than have the replies can be answered from his sig...........READ PEOPLE READ
Old 08-22-2005, 04:35 PM
nothing
reading comprehension>you two...hes obviously questioning what highroller has done to get him to 13.2@106.
Old 08-22-2005, 05:21 PM
Heh, your right.
And for all you know though, a few suspension tricks could be slicks for the track with some sort of traction bars.
Old 08-22-2005, 05:41 PM
Parting out 02 Type S :(
power3dfx's Avatar
sorry, although highrollers car may have a good amount of mods and be a 6sp, i will not believe that low 13 1/4 mile. do you have a slip? never mind the 1/4 mile et. at 106 mph, you need the best conditions and over 270 whp. allmotors setup na was pretty fast too, and it had similar mods!
Old 08-22-2005, 06:01 PM
highroller's Avatar
I do have some other engine mods and can feel a dime with my suspension set up the way it is . But because I have spies who frequent this forum I'll leave it at that. I am a newbe to this forum but an old fart when it comes to racing.
I run 20 inch rims and tires. Tires made to order out of Japan.
Old 08-22-2005, 06:04 PM
typeR's Avatar
...so you ran 13.2 at 106 on 20's ...well this is gettin more and more interesting...and it envolves spies no less. ...OOOOO KAY
Old 08-22-2005, 06:11 PM
I'm a Vagiterian.
All Mine's Avatar
I graduated early from high school, with honors.
You run low 13's on 20"s, and NA...... Interesting......
Old 08-22-2005, 06:16 PM
I'm a Vagiterian.
All Mine's Avatar
Old 08-22-2005, 07:34 PM
spdy0001's Avatar
HAHA spies
Old 08-22-2005, 08:58 PM
mrsteve's Avatar
Sorry you're full of shit
Old 08-22-2005, 09:13 PM
rtatsutani's Avatar
Thank you. Geesh I tell you, everyone is so quick to point dummy fingers now days.
Old 08-22-2005, 09:14 PM
I had more mods than I/H to run mid 13's... so a 13.2 @ 106 is very impressive. However that requires at least 300whp. I will not believe 106mph without ~290whp... period! I have about 271whp and I ran 103'ish mph on a busted clutch... maybe 104-105mph could have been possible, but I was never able to achieve that.
Keep in mind that the S/C'd Comptech 6spd with S/C, Header, Exhaust, clutch/flywheel on BIG rims (like your 20's) hit 104-105mph!! That car made 305whp.
Old 08-22-2005, 09:19 PM
mrsteve's Avatar
FWIW... on 295whp I ran 108 twice and a few times at 107 in my automatic.
Dyno on the 6-speed will get done as soon as I get off my ass and install the thermostat and switch.
Old 08-23-2005, 04:55 AM
typeR's Avatar
i think he means on a 6 mt...i dyno'd 257 and went 106 but ofcourse thats at 232 torque whereas a 3.2 would have to be much closer to 300 to have torque in the 230 + range
Old 08-23-2005, 07:03 AM
scalbert's Avatar
And you certainly were not running 20 inch rims.
Quick Reply: so im looking for more power...am i at the end of the na spectrum?
