Slotted vs. Combination Rotors
There has been a lot of discussion as to whether slotted rotors or slotted/drilled (combination) rotors perform better. I am quoting ROTORA's newest press release on their site to give evidence as to what brake specialists believe. If you go to www.rotora.com and go to the first press release about the Toyota Scion, you will open a PDF file which on the second page says this,
"SLOTTED DISC: For heavy track use, slotted is preferred. For SUV and truck applications, slotted is preferred.
SLOTTED AND DRILLED DISC: For aesthetic and light track use, combination disc is preferred."
Aesthetic use means that it has to do with looking good, i.e. beauty.
This is not to say that drilled rotors do not provide performance since even ROTORA makes a drilled and slotted BBK, but in the case of performance rotors the drilling gives no more performance above the slots. The rotors are already slotted so any drilling is merely for aesthetics.
It's true for SUV's & trucks. Slotted rotors perform better. I just ordered a set of these for my Explorer:
http://member.newsguy.com/~nutech/frames.html
-S namyaC-
The slotting was designed for letting the gasses escape that built up. However, it's been my understanding from the large brake companies that the pads that we use on the street no longer expell these gasses, so the slotting is moot. The only thing I could find that it helps is to keep a smooth pad surface, as it basically shaves the outer surface of the pad off every time you stop.
Drilling is what I found to be most effective, as it is just another aid to help cool the rotor. Notice on all the Ferrari's, Porche's, etc - what kind of rotors do they have? Drilled. However, our cars don't have the same cooling ducts those cars do, do there isn't the same cross flow cooling happening. Drilling can make a rotor more prone to crack under extreme heat, so proper cooling is needed. As long as that cooling is there, the drilled holes will help.
I found lots of info supporting solid rotors (well vented still) on street cars that aren't setup for additional cooling. They are less brittle, and provide more surface area for the smaller pads to grab onto.
Audi S4 driver
I think when done right and made for the braking system, slotted\drilled can be of benefit. Because come on, you can't tell me Porsche and Ferrari don't know what they are doing .. and they have drilled\slotted brakes on some models.
Although you cant go wrong with the slots. My front\rear set of Rotoras from the group buy will be here tomorrow with a set of axxis ultimate pads. Then ordering a UR crank pulley and off to the dealer for install![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
I can see this already turning into a flame war.
blader, Did you ever own slotted rotors before. They do work better and you will enjoy the better braking, but be fore warned that they do make an annoying noise compared to just drilled rotors. It sounds like a rattle snake. It's when the slots pass the pad even when not braking, but all the time. After time the sound lessens, but at first my friend was able to here it from his porch as I went by.
Audi S4 driver
Louie, no I've never had them before. What brand rotors\pads did you have and on what car?
Can anyone else with the Rotoras\axxis pads confirm this "rattlesnake" noise? I know some of you guys have them already.
I have the Rotora slotted rotors on both front and back with Axxis pads. There is absolutly no more noise than stock. No "rattlesnake" noise.
Audi S4 driver
I will have the exact same setup. rotora slotted front\rear and axxis pads.
Thank you DJ, that is great to hear, and thats what I thought the answer would be ![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
I will have the exact same setup. rotora slotted front\rear and axxis pads.![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
Audi S4 driver
/\ No. Drilled is too controversial for me .. lol
Not to mention more money and from what I've heard on here from people who's opinions I trust, its nothing but cosmetic differences with the drills.
Find beauty in dissonance
Their brake systems alone probably cost more than our cars.
I have the Rotora slotted and Acura pads. I didn't buy the Rotora because they were slotted, I bought them because they aren't Acura's warp-a-lot rotors.
Audi S4 driver
Originally Posted by evilstorm
i think its $16 more per rotor...not too much and worth it as long it doesnt crack or somethin..
How can you say its worth it. Your not even positive it won't crack .. "as long as it doesnt crack"
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
I think I'll pass. Slots are the safe bet and from what I heard, the way to go
Audi S4 driver
OK, I did some research on my own. Porsche casts their holes into their brakes. One site I read said it had something to do with removing water from the rotor better in the rain? I dont know how true that is.
Apparently holes that are cast into the rotor make a much stronger rotor than holes that are drilled after the fact. Pretty much everywhere I read said that drilled rotors will crack almost guaranteed in time, and only show benfit on "carbon" braking systems. It also said that Porsche rotors are ceramic .. I dont know what difference this makes though. All said that the slots are beneficial. Also saw a few pics of porsche racecars with large rotors that were JUST slotted, not drilled.
One site read that porsche started drilling their brakes in the 60s for uphill climb races, because it was less weight, but it was never intended to be used permanently. It also said that they would throw the rotors out after every race because they would crack pretty much every time.
Also read on one site that the reason Ferrari drills their brakes is to look good and so that they can charge alot for replacements
But I dont think that is true.
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
I have EBC's slotted and dimpled rotors. When I was at the track when I first got them I approached two other drivers with slotted rotors one was driving a mustang and the other was a GTP. they both said they had the same sound. I don't know what brand they had. When I called EBC when I first heard it, they said it was normal. May be ROTORA has a better set up
I just wanted to give you a heads up since I thought this was the norm for slotted rotors.
How do you like the setup you have and how long have you had it? I'm getting Rotoras but am still undecided on the pads?
I need FI
Originally Posted by Rod
That's basically why I'm going with Rotoras too, since the Brembo blanks are really no better than stock and the Rotoras seem to be the next best value.
I only have done the front rotors and pads, about 800 miles ago. 56k on my car. Basically sounds and feels like stock. They may bite a little sooner. There is a screw that holds on the front rotors. I had to use an impact screwdriver to get them off.
I have not done the rear yet. They are not as worn, and not showing any warpping. I'll do them this winter, too hot in my garage to mess with now.
I don't do any agressive driving, nor do I have a rough commute, or hit a lot of traffic (frequent 70 - 0 braking). I stayed with the Acura pads, less dust, good quality, take the heat OK. They came with packets of anti-squeal grease.
I also changed the brake fluid. I used Honda, but next time I'll use Castrol. The fluid looked bad at 56k. I may do it every 30-40k from now on.
Adventurist.
JakeCL: Did you ever know that your rotors are facing the wrong direction? Slots are supposed to sweep inward moving from the center of the rotor to the perimeter.
As for crossdrilled v. casted holes, it's all structural integrity and tolerance. Decreasing mass, IMHO, invites heat to linger and cracks to occur.
Porsche has a ceramic brake system (which you can get aftermarket for close to $10K...), it's basically the superman of brakes because they do not warp, keep temps low, and need no rotation or resurfacing. Can be had OEM on the current GT3.
So does Smitty's Rotora BBK (pic 46):
http://imageevent.com/smitty/2003acuracls
Did Rotora mark the boes wrong
-S namyaC-
Your slots are facing the correct way. The slots should face what looks to be the opposite direction of rotation. This is to keep material buildup out of the bottom of the slot if it were to face the other way, which can cause shaking b.c of the unbalance of the rotor.
The most important aspect is that the internal cooling vanes face the proper direction. A good set of rotors will then have the slots faced in the what looks like opposite direction.
Internal Vanes:
![](http://www.baer.com/Support/Images/Rotor3.jpg)
External Slots:
![](http://www.baer.com/Support/Images/Rotor1.jpg)
Internal Vanes:
External Slots:
![](http://www.baer.com/Support/Images/Rotor2.jpg)
Adventurist.
The theory that was popular for a while was to have the inside edge of the slot hit first and sweep outward. This helps remove the spent pad material, from the rotor. It was thought/observed in some cases where the slot swept outside in that the pad material would build up near the hub and cause a pulsating pedal. So, in that case, follow the manufacturers directions.
If the rotor has curved vanes in the center, make sure they are set correctly. This is not usually an issue since most slotted rotors for our cars are just straight vaned rotors and can run either way.
the boxes the rotors came in were labeled right and left, so unless rotora is trying to play a creuel joke im pretty sure they are on right
Adventurist.
Do the vanes of the rotor face forward or backward on the Rotora rotors? Vane direction is the key to knowing the proper direction. Vanes should sweep inward to outward to produce a vacuum effect.
08_UA7_Gr33k
02-11-2016 02:17 PM
08_UA7_Gr33k
09-27-2015 01:56 PM
09-25-2015 06:14 PM
