Slight engine knock normal ??
Old Apr 14, 2003 | 11:38 AM
6speedctrlfreak's Avatar
Hey guys....Is a slight engine knock acceptable with hard acceleration??? only happens after some stop & go driving (engine slightly warmer than "normal") when it happens it occurs at the lowest RPMs at the beginning of each gear range. Thanks
Old Apr 14, 2003 | 01:05 PM
scalbert's Avatar
No, you should not have any knock at all. Are you sure it is engine knock??
Old Apr 14, 2003 | 01:09 PM
Bill Faure's Avatar
I agree! Knock is not normal. Remember there is a "Premium fuel only" sticker on the inside of the gas flap. If you are burning 87 octane it could lead to a knock under hard acceleration.
Old Apr 14, 2003 | 01:32 PM
allmotor_2000's Avatar
Even with 87 octane you won't get knock for more than a few milleseconds... the Knock Sensor will pull back enough timing for that.
Sure you don't have a head gasket leak or something?
Old Apr 14, 2003 | 02:02 PM
CLBean's Avatar
1 Dog, 2 Cats and a G-Pig
Knock is not normal. It is bad... just use premium gas, and if you're still getting it then you have a problem... is probably something else.
Old Apr 14, 2003 | 02:43 PM
fuzzy02CLS's Avatar
I have no idea what a "knock" feels, or sounds like...
Old Apr 14, 2003 | 03:18 PM
tdtsai's Avatar
Maybe you had a bad tank of gas. You want to refill it when it is less than half a tank. Go to another gas stations to refill it,
Old Apr 14, 2003 | 04:02 PM
always use either Mobil 93 or Amaco93 but here in NYC Im always wondering if these dealers are messin' with the gas....sounds paranoid but....today I really got a chance to WOT and it actually isnt a "knock" in the '93 Ford Taurus sense....it actually might be the exhaust/engine growl. No flames this is my first real performance car !!!
Old Apr 14, 2003 | 05:55 PM
Doc.Booty's Avatar
Me neither. My car has a kind of "clicking" sound, but i dont know if that's normal or not. And i doubt it's a knock. I make sure to use at least 91 octane when i fill, usually it's 92 or 93.
Old Apr 14, 2003 | 06:13 PM
Mr Zipps's Avatar
I have the same "knocking" noise. When I take off slowly or the car comes to a complete stop. I asked the dealer and this was at the same time i got my tranny replaced and they told me it might be cause by the tranny problem. So I got the tranny replaced and have the same noise. Im going in for my 15000 soon and I'm going to ask them to check it again.
I will come back with a verdit..
Old Apr 14, 2003 | 10:33 PM
Wires's Avatar
Slight knock sounds like a bunch of marbles in a metal can. It goes from there to the sound of bolts in a can to a banging noise (that's usually followed by a melted piston).
rockyboy
Aug 4, 2024 10:35 AM
1fatcrxnem1
22
Jun 1, 2018 01:23 AM
govtcheez
Oct 1, 2015 12:21 AM
Mike Bertram
Sep 10, 2015 09:27 AM
HeloDown
Sep 8, 2015 06:51 PM
