slave cylinder mod ?
is their a way to remove the restrictor valve from our slave cylinder ?
There's info from the 3rd gen TL side....should be the same process: https://acurazine.com/forums/perform...-valve-734300/
Decided to do it after seeing how easy it looked.
Glad I did too. The slave was dirty as hell. Fully disassembled and now time to clean out and reassemble https://cimg0.ibsrv.net/gimg/acurazi...f3198d0dde.jpg |
Installed the modded slave.
Return of the clutch pedal seams quicker without the valve and clutch seams to respond a little quicker as well. |
