Should temperature effect my quarter mile time this much?
I couldn't believe how frakin slow the car was tonight:
Reaction .585
60ft 2.28
660ft 9.724
1/4 - 15.060
MPH 92.78
With my mods I feel like I should be faster despite the 60ft time. I hope nothing is wrong, but everything seems ok just s-l-o-w.
Reaction .585
60ft 2.28
660ft 9.724
1/4 - 15.060
MPH 92.78
This is too little information to determine a problem if there is one. But high temps and high moisture content will cause lower numbers. What you should look for is relative numbers of other cars at the track. That helps to discern if it is your car or all cars.
Originally posted by Ahmad310
i would have hate to have seen my times if i would have ended up coming there tonight!!!! ouch
1 Post
the elevation around cincy varys between 400 to 900 ft above sea level. I doubt that played a big part...I bet it was the Temps.
If the weather is nice I might try and make it to Edgewater on this wed. if you wanna go
Happy CL-S Pilot
At Convington, KY, on 07/05/03:
Time: 17:51
Temp: 87.80 °F / 31.0 °C
Dew: 73.40 °F / 23.0 °C
Relative Humidity: 62%
Pressure: 29.95 in / 1014.0 hPa
6.0 miles / 9.7 kilometers 11.5 mph / 18.5 km/h N/A N/A Haze
18:51
87.80 °F / 31.0 °C
73.40 °F / 23.0 °C
62%
6.0 miles / 9.7 kilometers 8.1 mph / 13.0 km/h N/A N/A Haze
19:51
86.00 °F / 30.0 °C
73.40 °F / 23.0 °C
66%
6.0 miles / 9.7 kilometers 6.9 mph / 11.1 km/h N/A N/A Haze
20:51
84.20 °F / 29.0 °C
75.20 °F / 24.0 °C
74%
29.98 in / 1015.0 hPa
6.0 miles / 9.7 kilometers 4.6 mph / 7.4 km/h N/A N/A Haze
21:51
78.80 °F / 26.0 °C
66.20 °F / 19.0 °C
65%
30.01 in / 1016.0 hPa
6.0 miles / 9.7 kilometers 16.1 mph / 25.9 km/h N/A N/A Rain ,
Thunderstorm Light Thunderstorms and Rain
22:13
75.20 °F / 24.0 °C
68.00 °F / 20.0 °C
78%
10.0 miles / 16.1 kilometers 8.1 mph / 13.0 km/h N/A N/A Rain Light Rain
22:51
71.60 °F / 22.0 °C
69.80 °F / 21.0 °C
94%
10.0 miles / 16.1 kilometers 3.5 mph / 5.6 km/h N/A N/A Rain Light Rain
23:51
71.60 °F / 22.0 °C
69.80 °F / 21.0 °C
94%
10.0 miles / 16.1 kilometers 4.6 mph / 7.4 km/h N/A N/A Mostly Cloudy
Time: 17:51
18:51
87.80 °F / 31.0 °C
73.40 °F / 23.0 °C
62%
19:51
86.00 °F / 30.0 °C
73.40 °F / 23.0 °C
66%
20:51
84.20 °F / 29.0 °C
75.20 °F / 24.0 °C
74%
21:51
78.80 °F / 26.0 °C
66.20 °F / 19.0 °C
65%
22:13
75.20 °F / 24.0 °C
68.00 °F / 20.0 °C
78%
22:51
71.60 °F / 22.0 °C
69.80 °F / 21.0 °C
94%
23:51
71.60 °F / 22.0 °C
69.80 °F / 21.0 °C
94%
Happy CL-S Pilot
Okay... here is your answer:
From conditions above at 6PM:
Density Altitude: 2171 ft
From the NHRA table here: http://www.tsrsoftware.com/nhra%20el...%20factors.htm
The correction factors are: ET: .9744 , Trap MPH: 1.0269
So your corrected times:
ET: 15.06 x 0.9744 = 14.674464s
Trap MPH: 92.78 x 1.0269 = 95.27 MPH
Happy CL-S Pilot
Now the Ultimate web page would do:
1) extract weather conditions from: www.wunderground.com The have tabular format for the weather conditions:
2) Using HP correction factor calculator from: http://wahiduddin.net/calc/calc_hp_abs.htm
3) Use the correction factor for ET and MPH from http://www.tsrsoftware.com/nhra%20el...%20factors.htm
Using your time slip numbers ..Dyno numbers if know.
Generate the table of the time, weather conditions, Air density and HP correction factors, corrected HP and Torque, corrected ET and Trap, estimated HP from each run...
Now that would be awesome!
1/4 14.4 at 95
i went to englishtown nj 2 weeks ago. it was 93 degrees out humidity was 83.. my worst run of the day was 15.092 and my best was 14.977 with just aem intake but weather does play a huge factor did u keep it in d5 or did you gate shift or did u try both and what did you find better
Happy CL-S Pilot
ah... summer runs are horrible.... check here: http://www.acura-cl.com/forums/showt...highlight=drag
mada51589
05-03-2022 08:54 PM
