SC Owners Need your Help
Sold but not Forgotten...
Well got informed in the afternoon that the charger was on, except for the guauges which were to be installed tomorrow. I drive down for the dyno, and was expecting some good numbers...
The dyno was done on a dyno jet, and pulled in 3rd Gear... Well here is the heart breaker...
Here is the complete info:
Max WHP=218.75 TRQ=226.49![what](https://acurazine.com/forums/images/smilies/what.gif)
Run Conditions: 69.16 F Humidity: 20% SAE:.98
Looking at the graph as soon as vtec kicks in it jumps a little, peaks at 5K and just goes downhill...
I didn't get the A/F Ratio graph which I should have asked for...
Any help is appreciated, cuz I really wasn't expecting those numbers... In short I'm slower with the SC than I was b4 all my mods...
Mods I know I should have posted this in the dyno section, but wanted as much feedback from our members.
Thanks,
Dyno Graph:
![Ugly](https://acurazine.com/forums/images/smilies/ugly.gif)
![Thumbs Down](https://acurazine.com/forums/images/smilies/thumbsdown.gif)
Thanks,
Dyno Graph:
![](http://www.acurainspired.com/gallery/data/6a61d423d02a1c56250dc23ae7ff12f3/full_1376_p37609.jpg)
Originally Posted by mrsteve
Your ESM conntection is bad, you car is seeing boost.
I spoke to the tech and he said that the esm is getting 2.8V as its supposed to... He was mentioning something about the EGR valve being clogged up. He cleaned it, and said it should be fine now.. I took it for a drive, but under vtec it is so bogged down... the car wont pick up like it used to...
I have asked him to connect the gauges before he takes the car in for another dyno. A bit disappointed but hopefully things will be fixed..
Thanks Smitty and steve for your feed backs...
You could tune the ESM, but the ECU is not seeing boost... if it did, you wouldn't be making 200whp! The ECU cuts timing when it sees boost.
Anyways, check for leaks first, slipping belt, adequate fuel pressure... what is the boost after VTEC?
Yep, check for 2 things ESM and BELT (needs to be tight). Also disconnect IMRC as Smitty said. What is your fuel pressure at idle? Make sure you don't get on it at WOT until you tune it.
Well up and early this morning.. gonna take the info to the dealer and talk with the tech.... thanks guyz with all your help and feedback.. will update you more once I get more if things haven't been resolved...
Wanted to ask when I get the gauges on.. what should the fuel pressure be at idle, and on boost what should it be?
Boost should jump to 5.5 psi at the most through out the rpm, with a peak at 6 correct?
Thanks again...
Thanks again...
Originally Posted by allmotor_2000
I set mine at 2.75V ![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
i wouldn't want anyone on here to start messing around with their comptech esm and adjusting it to where you have yours set. When i had mine on, it worked fine, set by comptech. you plug it in and leave it alone.
Originally Posted by ThinJim
if your using the emanage, you don't need to use the esm by comptech. the emanage has a voltage clamp built into it. perhaps you adjusted your emange to 2.75v and that works well for you.
Spoke to the dealer and they think the car isn't seeing any boost at all... so lets see.. just got to be patient and take it from there... They are hooking the mechnical gauges first, just to see if boost is there or not.. Secondly he said during the dyno, the car was getting lots of fuel.. but let see... waiting game...
Originally Posted by babyblue
Not using emanage since haven't decided if I wanna IC it yet... The tech hasn't changed anything on the ESM, just plug and play...
sorry to here things aren't going well with your blower. did you buy a new one or a used one? just curious.
Just FYI... one of the reasons the auto makes less power is precisely because of the 2.95V vs. 2.84V (even with the same boost pulley and same motor).
i was referring to allmotor and his remark. He uses the emanage.
Do you have gauges purchased yet? If not I'll sell you mine at 50% and include the fittings for the fuel pressure gauge.
Thanks for all your help by the way...
2.84V, 2.95V, 2.75V... they all work. The lower the voltage is, the more timing you get... then you use the E-manage to retard as necessary. With the Comptech ESM, I agree, they (Comptech) have set it to a certain value that is safe for their setup, FPR rise-rate etc.
FYI, the emanage has a map limiter which acts as the comptech esm, therefore you don't need the comptech esm.
Spoke to the dealer and he says the car is ALIVE
He took a road test and said he has a huge smile on his face... They re-checked everything and tightened the belt, which he said could have been the reason.. Dyno is set for tomorrow afternoon 1:30, so will know when it happens if everything fell into place...
Thanks everything for your help... Can't wait to pick her up tomorrow....
![Ecstatic](https://acurazine.com/forums/images/smilies/ecstatic.gif)
My car (CLS 6MT) dyno'd with 305 WHP at CompTech. Red Rider's car (CLS 5AT) dyno'd with 269 WHP before he added the HBP. I think he now gets about 285-289 WHP.
You should see at least 260-280 WHP with your setup. Good luck tomorrow.
Originally Posted by NSX-Tuner
A slipping belt could make a huge difference. I had that happen to me when I first picked up my car from the dealer after the S/C install. After tightening the belt the next morning, the car felt like it had another 75 WHP.
Well first and foremost thanks for everyones help in this matter.. especially to mrsteve, smitty, 02AV6 for quick responses and numerous pm's..... It was a lose belt, and they had to retune ESM... and couple of other things... be writing a review later on.... loving it so far...
Best Numbers on 3rd pull:
Max WHP=266.94 TRQ=237.15
Run Conditions: 68.99 F Humidity: 20% SAE:.98
A/F Was 11.4
**will post the graph later on....
I pulled 3 runs, with 91 octane
when I should have put octance 94... a little tuning was needed.... All pull were done like 7-10 mins apart.... So the car was warm... thermoblok weren't installed on the dynos...
Will be doing another dyno soon since I got the thermolblok later on in the evening and will be getting the mugen mods....
A/F Was 11.4
![Doh](https://acurazine.com/forums/images/smilies/doh.gif)
You were right on the money eh
Glad to see your car is running well. 266whp is a nice number. I suppose i've got the "factory freak" everyone keeps talking about so don't base your numbers off of what I put down. When I was N/A my numbers were normal (227whp) but when I dyno'd it again on the same dyno with the S/C I nailed 295whp.
Enjoy! Let me know if you have anymore questions.
08_UA7_Gr33k
02-11-2016 02:17 PM
lanechanger
10-13-2015 10:56 AM
