Rotora Rotors
1 Post
damn dude, I brake aggressively fairly often(more often than your average joe anyways) and mine are doing greatm excluding the initial rotor that was warped from teh factory :angry:.
I've had zero problems and I can't tell you how many times I've stopped from 110+ MPH very quickly down to around 20 MPH at the track. Oh well... IMO and i'm sure the majority of the forum would say the same... Rotora rotors do NOT suck.
Originally Posted by 4pumpedCL
I have stock pads on my car still...maybe that's what caused it.
I am assuming that you put NEW Rotora OEM sized rotors on and installed USED brake pads.... ..correct?
OEM pads are for grandma's... they outgas and create more heat than an aftermarket pad...
#1. never install USED pads on new rotors....
#2. You used OEM pads and EXPECTED better braking.
Look at it this way..
The pad is the MEAT... the rotor is just the potatoes...
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
Bad MEAT.. =
![Yuck](https://acurazine.com/forums/images/smilies/yuck.gif)
I have Axxis Metal Masters on the rear... They dust alittle too much for my liking... I have not researched new pads. You might want to look around and see what everyone else recommends...
The brakes are great, just too much dust for me...
I have used the Satisfied Pro Ceramics and Hawk HPS on Brembo OEM rotors.
Satisfied Pro's had good modulation, low dusting and noise but still warped a Brembo OEM.
Hawks are tricky to modulate smoothy and can be grabby after the initial bite. Groan a little when cold, low dust and still warped the Brembo OEM's.
Adventurist.
Rotora's with Axxis Ultimates are a good combo unless you hate dust.
I have the BBK and Rotora slotted/axxis in the rear and the stopping power is 1000% better over stock.
Originally Posted by StypeCL
Anybody use Akebono pads with there Rotoras? Cause I just got Rotoras all around and Akebono pads front and rear form SRD.
Silver Bullet
I recently installed slotted Rotora's and Axxis Ultimate pads. They started squeaking at about 50 miles in. I thought that it would go away after they had set in, but it just got worse. I now have over 1,000 miles on them and they still squeak under light braking. Not to mention the brake dust is about 10 times worse then my stock set up. Highly visible dust just after 20-30 miles of light driving. Has anyone else had this happen to them? Maybe I got a bad set of pads??
![Annoyed](https://acurazine.com/forums/images/smilies/annoyed.gif)
Adventurist.
No, Axxis Ultimate pads create A LOT of dust.... I have them on my car and it is normal.
Did you apply no-squeel when you installed the pads? Mine do not squeek....
Supercharged
I use Nissin brake pads with my Rotora rotors and they work very well. Nissin makes pads for AEM. No problems yet and they brake better then my old oem setup.
08_UA7_Gr33k
02-11-2016 02:17 PM
lanechanger
10-13-2015 10:56 AM
08_UA7_Gr33k
09-27-2015 01:56 PM
