Rotora BBK Rotors not holding up?!?! Is this normal?
I've had my BBK for about 50k miles and I am am about to order the third set of rotors for them. I've had the cross-drilled and slotted and am going to go with slotted only this time, but it seems really strange to me that these aren't holding up. It's my daily driver and I am really not that hard on it in the grand scheme of things.
Anyone else experience this?
thanks guys -- well, the first set I mistreated a bit, but this last set I have been good to. They look like hell and are warped (steering wheel pulses). I haven't really been rough on them -- been driving pretty easy lately as the miles have gone up.
I have TL a-spec wheels, so a little heavy.
Sounds to me like they arent warping, more like brake jidder. They just are simply "Glazing" over. Check out these articles.
http://www.stoptech.com/tech_info/wp...rakedisk.shtml
http://www.examiner.com/x-1060-Orlan...d-brake-rotors
all good info. I will take a pic of what they look like too, they look pretty ugly. I've also replaced the pads with ceramic pads when I got them.
Thanks.
Thanks.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
X-drilled + Slotted is too much, 1 or the other is the way to go
Good articles. Although I am relatively light, I did have an emergency stop a week an a half ago. I think I released right away (because I got out of the car), but this could be contributing to it. Will take a closer look and snag a few pics of my rotors tonight.
In the event that I need to have them Blanchard ground, any idea of where I can get this done? Local machine shop?
I am more familiar with double disc grinding, as I use that for many of the parts I manufacture for fuel injectors and fuel pumps.
Let me know if that Garnet papet works out for you, and make sure you DO NOT use emery cloth or regular sand paper...
B A N N E D
that is odd for 3 sets already, especially considering with how you say you are driving, but i thought the idea for a BBK was to help prevent the warping
but what it sounds like is that you have run-out issues, which over time cause the rotors to wear uneven, with then destroys the parallelism of the rotor faces, which cause the vibration cause the rotor is getting thin, and then thicker all in the same rotation
also do you got the 1 or 2-piece rotors, what size are the rotors, and also what calipers do you got
If you are having shaking, go out and try to bed the pads in with multiple hard non abs slowdowns from 60-70 and see if that deglazes them, they may not be warped, just glazed.
Blown is Best
Sounds abnormal to me. Check the rotor thickness.
The standard Rotora pads are the R2's. Have you been running the standard pads down to the metal backing or close to it?
I have not had that problem on my BBK and a friend who does more city driving is able to get 20K on a set of pads and replaces rotors after the 2nd or 3rd set of pads.
Whats up with RDX owners?
Have you bitched out Rotora yet?
B A N N E D
i think you need to find the root of the cause first, like checking for runout maybe (it would require new rotors though
but first as fsttyms1 said go and actually use the brakes HARD a couple of times, and see if they will deglaze themselves first (pad material may be built up onto the rotors) (also more aggresive pads may help too, then switch back to the pads you have now, and keep the aggresive pads as "deglazing" pads when ever you start to get a vibration from the brakes)
Blown is Best
Are your pads worn out? I've seen worse rotors than that. My first set of rotors actually had a ridge on the outer edge and had reached minimum thickness when I measured them.
Blown is Best
If that's the case, I would re-bed the pads and see how it performs. Easy driving can remove the layer of brake material off the face of the rotor causing it to grab unevenly.
Don't worry about the look of the rotor if you can get it to stop evenly. Run it until it drops.
Don't worry about the look of the rotor if you can get it to stop evenly. Run it until it drops.![2 Cents](https://acurazine.com/forums/images/smilies/2cents.gif)
Thanks for everyone's input.
B A N N E D
sound about right other then step 6 with the blue coloring tint to the rotors, but every one does precieve color different though
also in step with the "immediately accelerate back", is a little extreme, you can take some time getting back to speed, but yes do not fully stop with the scortching brakes, and try to keep moving at least some if possible
also once done the bedding try to drive a couple of miles further, to try and let the brakes cool off, before you fully stop, so you don't just warp them again
Blown is Best
http://www.stoptech.com/tech_info/wp...contents.shtml
From their instructions: "Note that, if the brakes of a vehicle with high-performance or racing pads are not used continuously in an aggressive manner, the transfer layer on the rotors can be abraded (literally worn off). However, the transfer layer can be re-established, if needed, by repeating one series of stops in the bed-in procedure. This process may be repeated as often as necessary during the life of the pad."
Former Sponsor
Ton's of good info on StopTech's site. Here's the page on bedding. Let us know how it works out.
![Agree](https://acurazine.com/forums/images/smilies/agree.gif)
http://www.stoptech.com/tech_info/wp...formance.shtml
Update: I tried re-bedding and it improved the pulsing dramatically...plus it was really fun to do. I think I will try it again to see if I can get it a little better.
Now -- onto my next question. Here are my old rotors. Are they repairable? Advice?
![](https://acurazine.com/forums/members/4ank-179286-albums-random-4854-picture-oldrotor-small-25386.jpg)
Its tough to tell, but they look like used rotors ![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
Meaning they look usable.
