Rl bbk
#81
Whats up with RDX owners?
CL lines work, the RL rotors are 5x120.
p.diddy (04-02-2012)
#82
Ohhhhhh okay that makes sense I figured it was something along those lines.
#84
The Rotora 1 piece setup was the smallest, but they dont make it anymore.
#85
Just to confirm will all 03-08 350z rotors fit or only the 05 35th anniversary with brembo brakes work?
#86
Only the Brembo equipped 350Z.
The other 350s have smaller rotors.
#87
I just looked up the specs on summitracing.com you are correct. They are expensive as hell for just a complete rotor set in cross drilled and slotted. I know I have to get cl rotors for the rear to match the fronts. Then I still have to buy pads lol. What do you guys recommend for pads? Anyone running the ebc green, red, yellow, blue stuff pads or maybe another brand? I would need to decide which ones to use.
I just like figuring out everything first before I decide what to do, so I only have to do it once right the first time ha.
#88
You dont need to get the actual Brembo rotors, just rotors for the Brembo model. Im running Powerslots, I think they were $200 for the pair.
For pads, I went with EBC Red Stuff. I like them, but if its raining hard out or theyre very cold, there is an initial pause between hitting the brakes and them grabbing. They are also harsh on rotors.
#89
Alright thanks for the info! Anyone else can chime in on rotors and pads options, the more opinions the better.
#91
i really like the way the RL BBK looks though its so NICE! but i wanna use my stock rims with a BBK for the winter and at teh same time fit a rim with a lip for the summer
#93
Weird
#97
Depends on the rim.
#98
i was thinking 18inch by 8.5 or 9 or 9.5 woudl that rub with out having to mess around with the camber or should i go with a different BBK i really like the RL BBK
#99
Depends on the offset and spoke design. We cant say for sure if they are wheels that no one has run.
The spoke design dictates how large of a spacer you need (if any).
The width and offset dictates if you will rub.
The only way to know for sure is to test fit.
#101
Find someone near you with a 3G TL 6MT or Type S and test fit your wheels on their car. If they fit that, theyll clear the RL brakes.
handsom-hustla
11-13-2015 05:04 PM
