Is this right?
Is this right?
Took the intake off, to install the p2r spacer. And I started the car up to have my friend rev it up to make sure the butter fly valves are opening up properly. Only one of the valves were opening, that was the one closest to the engine. The valve closest to the driver side tire was not moving at all. Whats up with that? Is this the IRMC valve I have been hearing about? Are they both supposed to open?
is it in the "open" position? i think thats the VSA. I believe how it works is that the plate is always open until VSA engages and thats when the plate closes. as the plate closes, the air is cut off to the engine, as if your foot was off the throttle, slowing down your car and cutting off the power preventing a slide or skid.
the IMRC is on the other side of the engine i believe.
