Review and Track Times: Comptech S/C + HBP
#121
Oh...Behave!
Originally Posted by mrsteve
I boosted it a few times tonight while crusing around. 7 psi is achieved at redline, from 5500-near redline I'm seeing 6.5 psi.
What pulley combo are you running?
#122
Originally Posted by scalbert
That is actually misinformation. You have to look at it as cost per elevated performance. The blower (or turbo) gives increase performance at part throttle and during day to day driving. The bottle only gives power on a rare occaision and only at WOT.
In other words, forced induction is used at least 50 times more often to one degree or another. If you were to use nitrous at that rate you would go through a bottle a day. $20 * 365 days/year = $7300 per year. After five years that is $36,500.
Hardly a cost advantage when you put it into perspective.
bottom line, the average s/c'd cl-s is gonna see my tail lights when it's time to race. this was proven during the WCM.
and when i said $500, i was including all the nitrous i've used since i installed the kit.
#123
#124
but in the real world, i get a chance to race someone on the street as often as you did when you had the s/c. which is few and far between. and 80% of the time i have enough power w/o the juice to get the job done.
#125
if we lined up @ the strip, you vs. me (no nos) i would still have a good shot at you.
#127
Originally Posted by Chaptorial
I'm not gonna look it up so can you please tell me what your best run w/out the spray was?
#128
Untrue, I'd race and beat you even with the blower pulled, at a road course or autox...
#129
in your stock 6MT? i doubt it.
#131
I'm not talking about solely racing, I was refering to general use. You don't use nitrous most of the time like you do forced induction. So the financial comparision is moot unless you restrict it only to racing.
do i think that the nitrous is more enjoyable than a s/c? hell no. i just haven't had a bunch of extra money to put into a s/c.
my mods are paid for and i'm happy w/ what i have.
#132
Maybe I was referring to a different 6MT and not stock.
#134
///M POWER
1 Post
thats only half the part. u gotta think about r/t tooo
#136
in no way am i implying that chaps or any other s/c cl-s is slow.
saying that i would have a shot at chap (no n2o) assumes that my experience would give me an advantage in the race. after he figured it out i would have to flip the switch to keep up.
#137
Well I figured out that the revs fly much much faster to redline than before the S/C :captainobvious: It's still hard to judge that 2 -> 3 upshift. And I've noticed that if the transmission senses you are too high in the rpm band to make the shift it just won't do it. It'll stay in 2nd gear until you let off the gas, let the rpms fall and shift again. If you time the shift right or even a little early it'll shift just fine. But I can't shift 2 -> 3 in SS mode at 6900 rpm and think it'll make the shift before the rev limiter. I need to shift around 6500 rpm for it to shift right at 7100 rpm. I guess this is somewhat of a "safety" feature to not break the 2nd or 3rd gear teeth I haven't had a problem in D5 or D4 since the first night, just driver error in SS mode. Also, traction is non-existant in 1st gear after VTEC.
#138
still a Masshole
#139
It has also happened to me before the S/C once or twice. It happened then while I was going down a hill. I think the "grade logic" feature of the transmission messes up high-rpm upshifts when you are on a steep downhill grade.
#140
Got a Job!
you kno what....my car does that as well...sort of
If I floor it through 1st into 2nd...and I decide to shift in 2nd rather quickly around like 3-4k rpms, instead of continuing all the way through 2nd into 3rd...it takes me 2-3 times to tap the shifter just to shift into 3rd.
#142
i've never experienced it on the track either, only on the highway.
i have that same 1st gear traction problem you do. as soon as i go WOT in 1st i have to shift into 2nd and i still hit the rev limiter sometimes.
#143
Originally Posted by darrinb
yup, his smitty's, titand19's and scalberts are all buried under ground
#145
14.1 @ 99
You're assuming i don't know how to drive, which may or may not be true. All skills being equal though my stock tires would put me at a rather big disadvantage.
And i'm just going back and forth here for nothing more then a mere conversation. Not trying to to incite anything either way.
#147
we'll have to wait and see
and you read Steves horror story about that guy amost slamming into him..
I plan on hitting the Dyno after the intercooler is polished and installed...
but for right now i need to fix my Fuel problem.... and i hope this new pump does the trick. :fingerscrossed:
#149
Smitty,
How much you gonna charge me to polish my I/C as well?
#150
#151
Originally Posted by Smitty
your going to wait a long time before I track the car...... insurance man does not cover my baby at the track...
#152
All i'm saying is that if i ran that in my cl with all my mods, that are fully paid for as well, i'd be pretty shocked.
and i'm not saying you are a bad driver, it's just that cutting a light and launching at the track is something you only learn at the track. and i've done it ~ 150 times.
RedRider found that out last year at WCM '03. he had 0 track experience and i was able to run better times simply because i knew how to launch and squeeze the best times out of my car.
but when we lined up on the highway... well, you saw the videos.
#153
the chances of something like that happening are 1 in a million.
we know that the true reason you won't take it to the strip is because you're anal about your car and you wouldn't want to risk hurting your baby. it's silly, but it's OK.
#156
New belt was installed today at Tischer Acura free of charge. I asked them to ditch the crappy "Dayco" belt they put on there at first and use a GY Gatorback.
Fuel pressure pegs out when I go WOT and then slowly backs off to about 85psi by redline. I haven't heard any detonation.
Aside from the S/C's blower whine, the B-pipe has totally transformed the sound of the car. While in 2nd gear, if I let off the throttle at 6500 rpm the exhaust lets out this huge "burble" for lack of a better term.
I'll be taking it easy tomorrow and then hopefully i'll be off work in time for my dyno appointment Wednesday afternoon @ 4:30. 285whp would be more than pleasing, although I might dump some octane booster or 100+ octane in there to try and get a 300whp reading
#157
We might just have different gauges that are reading differently. I have the Autometer Pro Comp.
Also, I only see 6psi in 1st and 2nd gear. For some reason I hit 7psi in 3rd gear. I'm swinging by the dealership tomorrow AM to have the belt tensioner tightened one last time.
I don't know why my vacuum is so low either... i was expecting it to be in the range you described. My fuel pressure is also lower than most, but I'm still running plenty rich as my dyno showed. My fuel pressure sits at 38 psi at idle when I first start up, but once I get moving it drops to around 35 psi or lower while crusing on the highway. When I go WOT it jumps to 98psi and falls back to just shy of 80 before redline.
#158
i remember racing brad @ milan, if i would cut a good enough lite i'd beat him to the end of the track with him realing me in very hard
j/k
Yes that one time you beat me,... not at the light, but at the 60' mark, (same thing?). I was seeing how far I could do a burn out, (about 50') and discovered that you could actualy get both tires spinning with the 5AT, as I drifted 15' to the left before I had to let off to avoid the wall,...then nailed it again and still caught you at the end, (almost).
#160
13.68 @ 102.56
I can't spin... I just hop
