reset ECU?
Old May 19, 2002 | 08:12 PM
32vv1ll's Avatar
reset ECU?
i just intalled my intake 30 minutes ago.....am i suppose to reset the ecu so the computer will recongnize the new intake?
Old May 19, 2002 | 08:39 PM
EricL's Avatar
It will figure it out on its own. As to how long it takes -- it depends. My ECU seemed to “accommodate” the Comptech headers and AEM CAI right away. I didn't notice any major gains over then next few days. (Others will disagree -- this is just my experience...)
Old May 19, 2002 | 09:06 PM
JRock's Avatar
Old timer
I'm pretty sure the proper thing to do is to unplug the battery for 30 mins then hook it back up and let the car run for a good 10 minutes and then drive it around a bit. Someone else probably knows the routine better.
Btw, make sure you have the Navi and Radio codes handy.
Old May 19, 2002 | 09:09 PM
Dom418's Avatar
I LOVE MY CAR
I did not reset my ECU after I installed my intake.... I should have though,
I really noticed a difference after a couple of days when the ECU had adjusted, much better...
Also, you're supposed to drive the car aggresivley right after you reset the ECU, which you would be doing anyway if it's your first ride after the CAI install.... you're gonna love the sound at high RPM's
DOM
Old May 19, 2002 | 09:22 PM
EricL's Avatar
AS a possible interesting aside... The folks at SCC disconnected the battery (reset the ECU) on their WRX and the power dropped way down after they did so. It seems that the computer -- at least in the case of the WRX -- enjoyed and rewarded their lead-foot driving behavior...
A comment that I should have included in my "just after header and CAI install" was getting on more than a few on-ramps to WOT the sucker...
I would expect that some "learned" ECU behavior might be better than some "fresh" ECU behavior...
YMMV
Old May 19, 2002 | 09:45 PM
32vv1ll's Avatar
i heard from the tl board that u dont need to disconnect the battery. all u need to do is pull the ecu and cruise control fuse...is that correct?
Old May 20, 2002 | 01:34 AM
EricL's Avatar
I'd have to pull the "Helm's" to double check (again), but, yes, you can "reset" the ECU without pulling the battery:
From an older thread and "mr tl"
"the proper way to reset the ECU (PCM) is to pull fuse # 13, clock/backup fuse (7.5A) from the passengers fuse box for 10 seconds
you dont have to let it idle at all
OR...you can use the honda diagnostic OBD tool...but i doubt anyone has it"
http://www.acura-cl.com/forums/showt...Reset+ECU+fuse
brboy
Oct 5, 2015 11:34 AM
Skirmich
Oct 1, 2015 12:59 PM
malvothegreat
Sep 29, 2015 12:38 AM
Froid
Sep 27, 2015 06:16 PM
ceb
ILX
Sep 27, 2015 10:56 AM
