Removing Passenger Door Help
I was trying to find a DIY or some posts on removing the passenger door, but cant find anything. My weather strip on the passenger side is torn and need to replace it as it leaks water in the rain or during a car wash. I got a replacement seal at a wicked price from www.acuraoemparts.com but need help removing the door. The seal that is torn is the one that goes all the way around the door. The door looks like it just has one bolt but Im not sure it is safe to remove. Anyone have any experience on this?
666 Speed
1 Post
1 bolt? If you want to take the door off, you have to prepare yourself for possibly annoying realignment. But i think that if you take the door off with the hinges, then you wont have to realign it later on. You have to take the front bumper off, then the pass. side fender and then you will see the hinges to the door. 4 bolts to the body and 4 bolts to the door. Remove the ones from the body. Then there is that metal thing that stops the door from crushing you when you walk in and out. That has a pin that you take out. Last is the wiring. Disconnect that from the door. Make sure that the door is closed at the time and then once its all loose, open the door carefully and make sure it doesnt fall! Oh and it would help to have your window open so you can carry it by the frame there...
"1 bolt? If you want to take the door off, you have to prepare yourself for possibly annoying realignment. But i think that if you take the door off with the hinges, then you wont have to realign it later on. You have to take the front bumper off, then the pass. side fender and then you will see the hinges to the door. 4 bolts to the body and 4 bolts to the door. Remove the ones from the body. Then there is that metal thing that stops the door from crushing you when you walk in and out. That has a pin that you take out. Last is the wiring. Disconnect that from the door. Make sure that the door is closed at the time and then once its all loose, open the door carefully and make sure it doesnt fall! Oh and it would help to have your window open so you can carry it by the frame there..."
man, i certainly know i wouldn't attempt this alone, that would be my advice. You don't want to drop that bad boy paint side down, that would not be pretty.
I'd say maybe take it to a shop for this one if you can swing it, just seems like alot to do in your garage, unless you have a hooked up garage i guess.
You both make good points. I was just trying to save as much money as I could on fixing this but I think I'll quit while Im ahead. Acura told me the part would cost a little over a bill and I got it for $20 oem. I'll just bring it in and get them to do it. He said he would charge me an hour labour so about $90. Thanks for the responses!
Originally Posted by Zippee
You should be able to replace the weather strip without removing the door.
I had thought about this but not sure it can be done for two reasons. First, take a look at this image
http://www.acuraoemparts.com/delray/...All&vinsrch=no
The part I need to replace is 19. it is the strip that goes all the way around the door and is 1 piece. I don't think I can get it around where it needs to go without removing the door
the second reason why I think the door needs to be removed is because I took a look at the strip on my car and removed it where it clips in and it looks like part of the strip should fit in a groove aside from the clip and I couldn't figure out how to get it to fit.
you sould not have to remove the door for that. the clips should pop out and the new weather stripping clips should pop in. looks like you just have to unbolt the #25 bolt to install the weatherstripping.
Door panel removal instructions are here (if you want to pull the panel):
https://acurazine.com/forums/audio-video-electronics-navigation-22/2nd-gen-cl-door-panel-removal-335272/
The above link is in the info sticky at the top of the forum...
https://acurazine.com/forums/showthread.php?t=335272
you should not have to remove the door for that. the clips should pop out and the new weather stripping clips should pop in. looks like you just have to unbolt the #25 bolt to install the weatherstripping.
When I changed the seal in my RX7 I was able to get it in place by going over the door from the outside.
rockyboy
08-04-2024 10:35 AM
