Reminder to S/C'ed Owners!!!!!!!
#41
4drs just wanna have fun!
Originally Posted by mrsteve
The effect of opening the runners increases the volume which is supposed to slow down the airflow and thus increase density (increase "boost") which is why we see problems with the HBP and IMRC.
Well either way I think that if you just ad fuel before it kicks in most people should be fine, I think the issue was people were trying to get around this at first with the Comptech FPR and ESM.
#42
Lives On BOOST
I should be having the car done by early next week, but I won't be able to tune until the weekend. Should I be alright if I leave the IMRC connected till then? (Obviously no mashing!) Should I invest in a KnockLink?
#44
Hey all,
I'm new here, so forgive my "n00bness". I'm not green to tuning supercharged / turbocharged engines, however. What's wrong with the Comptech provided tuner? I seen posts with people referring to other ECU tuners as a solution. Does this imply that the Comptech provided ECU tuner can't help the ECU find stoich (adjusted fuel/spark tables) at part throttle settings? Shouldn't you be able to add fuel on the WOT table to compensate for the lean spot, and pull timing for the increased boost?
Also, does the Comptech kit have a inlet charge cooler?
#47
Let me think about it, here are my thoughts on it:
Removing the plates would hurt the low end of the car a good amount, there are times when you are off boost and the plates closed would help out the NA portion of the powerband. Otherwise if we're talking about on boost power with no plates at low performance it would stand to reason that the boost levels would go down a slight bit be of the extra volume the blower must fill, similar to when you go from a 3.0 to a 3.2 or 3.2 to 3.5 and the boost goes down since it needs to fill the cylinders more and thus the same occupies more volume now. If you tune for the extra volume you might see some gains since the air charge will be cooler from being less compacted and the slight reduction in boost stacking. It seems that the you wouldn't lose much power since the SC is spinning at the same speed (unlike changing the ratios with a crank pulley and reducing boost in this manner).
#48
#51
Originally Posted by rjurado_1215
but im also going to have to think about this. first thing to find out is why acura really put this to begin with hard facts not assumptions
Thing is this still applies when your supercharged and off boost when the bypass valve is bypassing the supercharger due to high vacuum (low throttle opening).
Question is what difference is made with the change in volume while under boost.
#53
Blown is Best
Originally Posted by Ojref
Hey all,
Unfortunately, there is not a readily available inlet charge cooler. Scalbert custom made 5 aftercoolers that have been owned and resold on these boards but that's it.
#56
not since last. im p&p the plenum and runners and going to get the king tb next. car is all torn apart right now. and went with a different setup. last setup was not for everyday driving. and im redoing the whole fuel side of things
#57
Trolling Canuckistan
#59
can some one clearify to me which is the HBP? the smaller or bigger pulley?
and the IMRC i'm suppose to disconnect is right in the rear of the back plenium in the middle just under the strut bar of the manifold?
#60
Blown is Best
Standard = 3.0"
https://acurazine.com/forums/showthread.php?t=143223
