Rattles
6th Gear
Rattles
Does anyone else have this problem?
When the stereo is turned up loud the back brake light shakes in its enclosure creating a ridiculously annoying rattling.
I know a lot of people complain about rattles in general with this car. But does anyone else have this same problem and if so have they fixed it. I tried tightening the light....didn't help...it's really annoying me.
thanks
2001 CL Type-S
black with parchment
thanks
2001 CL Type-S
I had this EXACT SAME PROBLEM!!!
Did you have a spoiler installed?
I had the dealer put my spoiler on, and they removed the rear center brake light to disconnect it, and the JERKS never re-attached it with the nuts! They just left it loose!!! So when I turned up the radio, the speakers vibrated the brake light and it caused my squeeks.
check under your rear deck, from inside the trunk. You should see two bolts coming down which attach the brake light to the frame. Check to see if they are tight.
Good Luck
Good Luck
![](http://www.geocities.com/jerry5180/alien2.gif)
marcelft
07-10-2018 06:17 PM
CheeseyPoofs McNut
10-11-2015 11:25 AM
jaynatlanta
5G TLX Problems & Fixes
09-15-2015 11:08 AM
3GTLOwns
09-09-2015 09:51 PM
