Ran a 01 Z06, holy crap!
Parting out 02 Type S :(
I knew i would get my ass handed to me but the car was feeling very happy and pulling like a mad man so i reeled him in.
First run, we are already at 100 so i had to start with 4th, he was a car behind, by 125 he was already 2 cars in front. I could of done better had i been in vtec, but it was too late by the time we both backed off.
After the run, he slows down alot, till about 80. I do the same to see if he would line up.
He took his time but finally came right next to me and we cruised together at 80 mph. I was ready this time in 3rd and we both punched it at the same time. I kept up to 100 and he started to pull away. Took it to 4th and he had 1 car on me and was walking away from me at this point. We went up to 130 and he had 2-3 cars on me.
I really thought he would of taken me by alot more considering its a Z06, but then again he might of not been trying too hard or just couldnt drive it well. He was really surprised that i kept up in the lower speeds so well, and after the runs, he followed around me to check out the car.
He had tints and i couldnt give a thumbs up to him before i exited so i just highbeamed a couple of times and took off. Didnt get a response from him, but im kinda glad he didnt put his hazards on!
Overall a very fun night coming home!
Blown LS6!!
Did you get any gains from the tuned E-manage??
Originally Posted by darrinb
nice run, in 02 they got 20 more hp
as for the emanage, i did a dyno right before allmotor retuned it. peak hp was 254 (ill post dyno later), but my AF ratio was 10- all through 5500-7000 rpm so i was losing alot of power.
after we did a retune, i get low 12's, high 11's. the car feels at least 15 hp at the wheels stronger. ill post the dyno so that you guys can comment on it.
my final mod is the thermoblok assuming they fit in, that should net me with a solid 280 whp i am hoping.
Blown LS6!!
Originally Posted by Chemmech
Get the intercooler. BTW, where did you go for the Dyno?
If I could find 3 more people interested in the intercooler I think Scalbert might do another production run (he wants at least 5 people).
Is the 15-20hp gain with the emanage a small peak or do you see gains all across the powerband?
Originally Posted by allmotor_2000
You get 15whp flat across the power-band... we arn't tuning just one RPM point.
Wow! Cali. gas must really kill the horsepower on your car. Either that or the stock exhaust system is very restrictive with the Comptech charger. My car made 295whp with Comptech S/C, HBP, Headers, Catback... un-tuned.
Blown LS6!!
I also think you have a freakishly fast CL.
u s/c guys should tune a map on the e-man with 100 oct for track purposes
Originally Posted by Seattle Cl-S
Where's the cheapest place to buy an E-manage? I guess I'll need a wideband O2 sensor as well?
you need a way to monitor AFR so a wideband is necessary, unless you decide to get dyno'd. however, i would recommend the wideband regardless because it is good to have it around to monitor AFR at any time.
for example, i noticed that my AFR would stay around 12 in all the first 3 gears, but when it hit fourth, i would hit 13's. without the wideband, i wouldnt know about it. but i was watching it and let off when i saw this to prevent running too lean. (this was when i was playing around with the z06)
Adventurist.
Blown is Best
Originally Posted by NiteQwill
Once I get my S/C on.... I'm for sure in for the count. ![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
For us peeps in cali, the emanage helps more!
Finally, the 254 whp i made is a result of a very jumpy and rich fuel curve. I hit 10.0 and below for most of vtec, which sapped my high end power. Since the retuning, my curve should be very similar to yours, without the dip to 11's though. Now i just wish the next dyno day would be sooner than 2 months!
acuratl26
04-23-2020 07:30 PM
