i could have. but this is somewhat the same. the only thing pspec has that i dont is that i cant adjust the height of the shifter. but this height works for me. if anything ill cut it down and weld it at work if i want to make it shorter. which i might do, and wont cost me $200. just the $90 i payed for the ss kit.
removed the clutch dampener, so tomorrow im gonna beat on the car and bleed the lines. then ill report back.
civicdrivr
close
- Join DateJul 2008
- LocationVA
iTrader Positive Feedback100
iTrader Feedback Score(9)
Liked:8,746 Times in 5,159 Posts
Honestly I think the P-Spec shifter has a shorter throw, plus the throw itself is adjustable.
But if yours works, why change it?
update.
the rest of the nitrous lines came in and got my aerocatch carbon fiber look, locking hood pins
I wanted those latches but nobody was willing to install for me.
You'll be the first CF hood with pins from my recollection.
I couldn't find a solid place to mount.
Can you please take pics of where your going to mount/drill everything and how you're doing it?
ill try my best at taking pics and mounting them. ill see what i can come up with on where to put them.
im gonna install the lines now and if i have time ill start the hood pins.
civicdrivr
close
- Join DateJul 2008
- LocationVA
I got those as well, just in black. They're for the track car. They are very nice. I like how you can use them as door handles too.
Quote:
door handles Originally Posted by civicdrivr
. sounds like a pita to open each door at one time and each time u want to get in the car after locking it
Never thought to use them as door handles.
civicdrivr
close
- Join DateJul 2008
- LocationVA
Yea, Ive seen some racers with fiberglass doors use them, not the locking type obviously.
Boats use them too. I played with them for 30 mins when I got them. Theyre pretty cool.
crazyasiantl
close
- Join DateJul 2008
- LocationClovis CA
- Age38
iTrader Feedback Score(7)
Liked:597 Times in 431 Posts
nice build
update
got my car detailed. the clear coat on the roof and trunk are fucked. i got these deep circle like scratched on them. they couldnt get buffed out. need to be sanded and painted and clear coated again. so now, i will be ordering a cf trunk in the next month or so and have to think of doing something about the roof
here are some pics
hood
door
sun roof and roof
here are some pics
hood
door
sun roof and roof
That sounds odd that they couldn't be buffed out...
Who is buffing them out?
my friend. he tried what he can and got the small one out. we think that the the guy either parked under a tree and those lil tiny green things fell from it and he just didnt care. also have some bird shit on my trunk that wast removed right away and it ate through the clear coat.
my guy detail my car for a few years now and worked magic. but this he said he cant get out unless u went sand and spray it with clear again.
Unregistered user
did he even clay bar?
anyways he might need to use a wool pad and a different buffer..
Clemson Tiger
Dude you should just get a black vinyl overlay for the roof. Would look good with the trunk and hood
Either repaint it red, flat black, or vinyl overlay it cf or gloss black
Hmm...got any pics of the scratches?
their not scratches. their 1/16"-1/8" dots, and some dots have like cob webbing coming from them. it just rained so u wouldnt see anything in the pics i take
Oh...then yeah I'd just go with a vinyl overlay.
Unregistered user
Quote:
sounds like the paint "cracked" its not repairable.Originally Posted by Rajca
its not cracked. the dots have small lines about an 1/8" the go out of the dot. what ever. its not meant to be a show car. ur not gonna notice it going fastl
got my cf shifter. some customizing required so it looks good bc of the way the boot mounts. but it looks great.
aluminum housing with cf wrapped around it. real cf too
spent a few hundred dollars on front brake parts and hoping everything will be here by sat. bc sunday im taking my car to a time attack at joliet autobahn
cross drilled and slotted front rotors
ebc redstuff front pads
dual piston legend calipers
dot 4 brake fluid is getting put into the clutch hydraulics.
i saw one bleeder screw for the clutch. is that all or did i miss any
Legend upgrade huh...nice mod.
Not sure about the bleeder screw.
went to a parts store and they said that the quickest they can get them is monday. so im gonna borrow a friends since he has two laying around. then ill order them down the line.
got the old fluid out and put dot 4 fluid in, blead the system (only found one bleeder screw). gonna get my bottles filled friday.
anyone know where i can get my fire extinguisher refilled? fire station?
Quote:
what caught on fire already that you had to use it?Originally Posted by Rajca
Probably been practicing spraying stray cats...
Unregistered user
lmk if u want a cf trunk. i'll be ordering mine soon, maybe they can give a deal...
hopefully mods won't mind. its not my shop, its not me selling, its not a groupbuy; its me trying to help members. if its a problem or you need clarification PM me. though i wont be able to answer till next friday.
