Rajca's Project CL-S6 Car
wham bam thank you ma'am
well, the car passed the inspections.
, so im gonna drive it tomorrow to work and see what kind of balls it really has. so far, it has surprised me with how quick it accelerates and how easy it is to drive. than gonna get my custom cat back (axle back??) exhaust done
If my memory serves me well...I thought that if you ran a turbo setup 2.25" was better for the back pressure than 2.5"
Can't remember though...
im doing the exhaust just for now, since its bent a bit before the mid muffler and they y pipes arnt exactly straight and i have tlp mufflers. so im gonna go with a 2.25 pipe. then when i go turbo ill go 3"
15.5 lbs:
http://www.tirerack.com/wheels/Wheel...All&sort=Brand
not about to spend $400+ on a rim. and if i can ill buy some used ones since it will be cheaper. not worried about if they have a few scratches and what not. just so their around 15lbs and 17's.
anyway, took the cl on the highway today and it feels strong in all gear. has lots of power.
but the things that annoy me are:
when the windows are open its extremely loud inside the car above 50
and when cruising at 60mph the rpms are at 2100. fuel economy must not be too good at that rpm bc in my tl-p my rpms are at 1800 at 60mph. and i get 29+mpg. is that how it is in the other cl-s6's?
other than that, im gonna go and hook up my nitrous to it now
I recently went on a trip through the mountains and was cruising at 75 when I was on the interstate and accelerating/decelerating in the 45-60 range in the mountains and I got 31 mpg
Want to maximize mpg's.
Drive 55 mph on the freeway.
You can find more info. here...
http://drive55.org/
Some friends of mine up in Sacramento have been experimenting with this and they are getting ridiculous mpg in the CL, TL, and TSX.
I think it was 41 mpg in the CL.
http://drive55.org/
http://drive55.org/
http://drive55.org/
When gas was $4/gal last summer I started driving 50 mph just to see what kind of impact it was going to have on my mpg. I was driving a '06 Mazda 3, 5 speed at the time. 2 tankfuls, I was averaging close to 50 mpg.
I kept getting pulled over by NJ State Troopers(no tickets) and harassed by semi truck drivers even though I was always driving on the slow lane.
installed my neuspeed short shifter today. took about 15min to do. and i love it. shifts are shorter and a lot quicker. well worth the money if u can find one.
anything in green is a work in progress
anything in red i have but not installed
anything in blue is done/installed
repair list
-CF hood
-Front bumper
-Rear bumper
-Rear left tail light
-Front headlights
-Grill
-Paint
-Mufflers
-Bulk head cover
-Straighten out bulk head
MOD list
-CF trunk-
-Clutch dampener removed-
-SS clutch lines-
-Neuspeed short shifter kit-
-SS Brake lines-
-Legend Dual Piston Calipers-
-Dimpled/slotted ebc front rotors-
-New Hawk performance street pads-
-MOGG End links-
-3rd gen tl Progress rear sway bar-
-Neuspeed strut bar-
-Tein basic coil overs-
-Tint, 10% rear, 20% front-
-My custom turbo kit-
-Cusco under brace-
-Light weight 17" rims-
-My custom radio delete gauge cover-
-GM Friction Modified Syncromesh MTF-
-Dot 5 Brake Fluid-
-Flush and Bleed clutch line-
-Flush and refill coolant-
-Intake manifold spacer-
-Throttle body spacer-
-NRG engine torque dampener-
-UR light weight crank pulley (oe size)-
-Custom nitrous setup-
repair list
-CF hood
-Front bumper
-Rear bumper
-Front headlights
-Grill
-Paint
-Mufflers
-Bulk head cover
MOD list
-CF trunk-
-SS clutch lines-
-SS Brake lines-
-MOGG End links-
-Cusco under brace-
-Dot 5 Brake Fluid-
Nice.
I wish I could run through the gears on a CLS 6MT with a short shifter just to see how responsive it is.
Still haven't even been in a CL with the 6 speed.
Damn...
Damn...
Nice progress.
How much was the bumper spray?
I am about to buy a front bumper, my car came from a front plate state but AZ. does not have them so I have two ugly holes in it.
it feels awesome with the short shifter kit in. feels great.
got some dot 4 fluid, didnt have dot 5 so dot 4 will do for now. and also bled the system.
stock line
ss line
repair list
-CF hood
-Front bumper
-Rear bumper
-Front headlights
-Grill
-Paint
-Mufflers
-Bulk head cover
MOD list
-CF trunk-
-SS clutch lines-
-SS Brake lines-
-MOGG End links-
-Cusco under brace-
-Dot 4 Brake Fluid-
-Flush and Bleed brakes-
stock line
ss line
repair list
-CF hood
-Front bumper
-Rear bumper
-Front headlights
-Grill
-Paint
-Mufflers
-Bulk head cover
MOD list
-CF trunk-
-SS clutch lines-
-SS Brake lines-
-MOGG End links-
-Cusco under brace-
-Dot 4 Brake Fluid-
and here's a thread about it -https://acurazine.com/forums/showthread.php?t=716063
i payed $130 for my front bumper but it was used and had some deep scratched. a new one from the dealer is about $250. got it painted and fixed a bit for $150
Mine has the holes and a gouge in the center top from when I did not pull far enough into my garage and the door hit it.
It also has 170k of freeway micro chips that don't show up in pictures but drive me crazy when I get within ten feet of the car.
150 to paint the new one is about I expected.
price will vary depending on if u have pearl, metallic, ....
im gonna take my ur pulley off my tl and put it on the cl, now. i guess i wont be doing any stock dyno runs or stock 1/4 runs. o well
since i added the short shifter kit. and it feels amazing going through the gear. i also cut about 3/4" of the threaded shifter pipe (pic below). and then drilled out the stock shifter so it sits lower when i screw it in. i love even more now.
