Rajca's Project CL-S6 Car
#1293
B A N N E D
and lowering too much, can also screw up the suspension geometry, which greatly offsets any benefit from the lower center of gravity (let alone losing suspension travel too)
#1295
and actually being too low would mean you should really be slowing down for everything , where like on mine, being higher, i clear most things (i JUST fit over most curbs), i can actually drive the over things like a speed bump like a normal car, and hardly have to slow down
#1296
B A N N E D
and this one spot on the highway, i can actually feel it/mine bottoming out when i do like 80-90 (speed limit 65) over it (but it is worse in the right lane though, compared to the left), so i would like at least stiffer shocks for that (but even now they are right about the right stiffness for things, because the car is very well mannered considering it's lowered actually), but then again most stock cars, with about the same speed, you can actually feel them bottom out/touch the bump stops
#1299
Whats up with RDX owners?
Wheres the inlet and outlet on that intercooler? Id look into raising that up. No offense, but it looks kinda cheap hanging out like that. Did you remove the steel bumper bar at all?
#1301
Remove the metal bumper. You dont need it unless you plan on hitting something
Think of the weight reduction too.
#1307
