Quick, keys locked in car!!!!!
Old Aug 12, 2003 | 03:50 PM
jts1207's Avatar
Duck Fuke!
what can I do?
Old Aug 12, 2003 | 03:51 PM
darrinb's Avatar
///M POWER
call acura tlc 1800-594-8500
darrinb's Avatar
///M POWER
have ur vin # ready btw
Old Aug 12, 2003 | 03:55 PM
jts1207's Avatar
Duck Fuke!
thanks
Old Aug 12, 2003 | 03:58 PM
wuzzz619's Avatar
I didn't think it was possible to lock your keys in the car???
Old Aug 12, 2003 | 04:00 PM
Nashua_Night_Hawk's Avatar
Happy CL-S Pilot
where is number #2? how about the valey key?
Old Aug 12, 2003 | 04:20 PM
NOVAwhiteTypeS's Avatar
go to a gas station, slim jim, or just call roadside asstance
probably had the key in the trunk or on the seat then locked the doors and shut doors
Old Aug 12, 2003 | 04:26 PM
Doc.Booty's Avatar
Hmm someone's done this before
Old Aug 12, 2003 | 04:45 PM
kevin79925's Avatar
CALL ONSTAR!!!! hehe
Old Aug 12, 2003 | 05:00 PM
jts1207's Avatar
Duck Fuke!
actually, i work at a honda dealer and was having the car washed and vacumed, well the lot tech left the keys in the ignition and had the driver door closed, bumped the passenger door lock closed the door and there you have it............service was gone called acura and the guy came out and used the "miracle tool" wedged the door open and popped the lock...............thanks for the help
Old Aug 12, 2003 | 05:30 PM
JaDia4's Avatar
Censored User
From: Miami - just one day, I would like to drive without getting cut off!
I have and my cell with them too. Locked myself out during a morning workout. But within an hour TLC had a local locksmith there to help. He made a new key in the back of his truck, which only unlocks the door and starts the generator. I now tie that key to my shorts when I workout.
Old Aug 12, 2003 | 07:16 PM
Smitty's Avatar
Oh man... that sucks...I hate that sloppy slim jim crap.. makes me cringe when I see that being done... I think if I ever have the door panels off I am installing a piece of sheet metal over that so they can't slim jim my shit..
Old Aug 12, 2003 | 09:11 PM
Ant7701's Avatar
Sweet as Gold
our cars are un-slim-jim-able....there is a cover over the rods and actuator...unless you break that cover off...which would be almost impossible to do with a slim jim...it aint happening. He used the wedge tool which is a little pocke that u slide in the door crevice and pump w/ air to inflate pocket so the door opens slightly and then you can get a coat hanger inside to pop up the lock...
Old Aug 12, 2003 | 09:15 PM
danny25's Avatar
when mantis left his keys in his car the roadside assistance guy used a wedge between the window and door. And then only used a metal hook kinda thing that went under the window and came back up inside and hooked onto the lock and pulled it up.
Old Aug 12, 2003 | 10:21 PM
PimpinCLS03's Avatar
A CL-TYPE S 6 SPEED OWNER
Thank god for Onstar. If you lock yourself out, one call is all it takes and they unlock the the driver door for you using a GPS Satellite......its the shit!
Old Aug 13, 2003 | 01:29 AM
AK_MOBBER's Avatar
VOTE OUT THE BUSH REGIME
I locked myself out of my TL and opened it up by using a coat hanger to pull up on the lock. It took a while of fiddling with it but it really isn't that hard. Just watch out so that you don't rip your door moulding.
Old Aug 13, 2003 | 02:03 AM
kHmER Co's Avatar
mister D
was the window open? if not how. lol i know the older gen accords are stolen like that. but i dont think the cl is under the same catagory
Old Aug 13, 2003 | 07:03 AM
ST2000's Avatar
I got locked out once athe RMV when i was swapping my vanity plates, so the keys were locked in the trunk and the doors were locked too. Called up TLC, guy came and actually had a hard time wedging the door open and using a small metal rod and with hook thingy at the end to fish the lock knob. He ended up messing up my chrome door molding, had to get it replaced outta my own pocket, sucked donkey balls, but lesson learned.
Old Aug 13, 2003 | 07:11 AM
lrutt's Avatar
gotta love my Ford F150 with the number pad on the door. just hit the code and I'm in. No worries.
Old Aug 13, 2003 | 04:46 PM
my friend tried to bruteforce my aunts ford explorer eddie bauer edition w/ the number keypad
Old Oct 31, 2019 | 10:35 AM
Max Honeyman's Avatar
This is the best way to unlock this car
Originally Posted by jts1207
what can I do?
No one here has said it but for people in 2019 with a TL.. The hands down best way to unlock it for free is the shoelace method. I tried it with my 05 and it worked in 10 minutes.
*Take a shoelace
*tie a slipknot in the middle of the lace
*stick the shoelace behind the door
*use a flossing motion to get the slipknot over the lock
*pull both ends to tighten the slipknot and pull upwards to unlock to car
There are plenty of YouTube videos showing the procedure. I used a coat hanger to stick the lace in past the weather stripping. And a screwdriver with a rag to gently pry the door to get the lace in. One it was in no more prying was needed.
If you accidentally tighten the slipknot early or ruin the knot you can re-tie it without pulling the lace out of the door..
Cheers.
Old Oct 31, 2019 | 03:02 PM
whitetiger5's Avatar
Max, welcome to Acurazine.
Old Nov 1, 2019 | 01:41 PM
Karanx7's Avatar
Unregistered Member
Welcome to AZine, Max Honeyman.
peti1212
ILX
22
Jan 5, 2022 05:14 PM
tman570
Jun 11, 2019 07:56 AM
nanos
Nov 12, 2015 08:41 PM
Aug 30, 2015 02:39 PM
